Ordered 5 of them.4 are immediately going into a (jetbeam T6) with the stock driver.
I’ll post results in this thread in about 2 weeks. Anyone wanna take a guess what 4 OW,s will do in a 80mm ish T6 housing, Lux wise?
I just finished installing a the older Olsen flat black with MTN fet driver running 2P pani/3400 in a astrolux MF02. As far as hot spot intensity goes. It seems more intense then my BLF GT on a white wall 100 yards away. Going bonkers with properly centering this tiny led. Anyone wanna guess what this light will do, lux wise? once i get it properly centered? The MF02 reflecter is a fairly ringy and simply a poor quality reflector. So I’m not expecting anything amazing here.
The answer is it depends on used battery. Anything in Samsung INR30Q class is not good for White Flat cause they will pull from 7-8A in DD mode significantly downgrading lux performance.
With White Flat you want to stay somewhere at 5.5-5.8A current draw. So use Sany GA, LGBD1, or any other low current cell that will not pull more than 6A out of emitter.
It depends on how good your heat path is. If your reflow is done well with enough but as little as possible solder, on a DTP board that is thermally well mounted on a good heatsinked flashlight body, then 5.5A to 6A may be the sweetspot. But if everything is less perfect, this led (small die, high heat) is very finicky about that and will have its maximum performance at lower current.
To me, judging by the graphs i’ve seen, it seems to be the maximum reasonable current.
Above that you hardly gain any output.
It will age the LED faster and mainly more heat will be produced.
Vf will also be higher.
The difference between 850 and 950 Lumen is not worth it i.m.h.o.
Except that this led is exclusively about throw. It has no great tint, a low CRI, a bad efficiency compared to bigger die leds. The reason to use this led is throw, also that last bit, and you want to be as close to max as you can without killing the led.
You should only do this if you only use it for a few seconds at a time or the flashlight is very large and never gets warm/hot. As soon as the flashlight becomes warm, the LED will overheat when driven at it’s absolute max (who’s was measured when cool).
In my kind of led-test the led was already pretty much warmed up when arriving at max. But my tests give no clue whatsoever about the lifetime of the led.
I get the dragster attitude, i get the fun of that, but it’s just not my attitude.
I want my lights to be able to work on full output for a long time, and if possible, with decent efficiency.
With this low Vf of the ‘White Flat’ this can be achieved while still having amazing throw.
I will not win the light meter candela race, but i wonder if the difference between 850 and 950 Lumen will be noticeable by human eyes.
In fact, i’m thinking about running them at 4 Amperes maximum actually.
It will have to wait for now though, i’m busy with the BLF scratch build.
Well this is watt I was alluding to in this intently “loaded” question and I was waiting to see watt replies if any it generated. Yes the latest version Osram KW has higher lux than XPG2 but with caveats. And they are significant caveats in an ever more popular FET driver world. Osram may improve the KW’s current handling abilities in the future and when that happens well it’ll definitely without caveats be The King.
Past certain amps the dedomed XPG2 S4 2B today is still King IMO. Butt let’s face it. LEP technology currently lux surpasses all LEDs out there with all 1:1 input factors considered. And the thing is it still has room to improve.
Guys this is not Black Flat it is White Flat… Seems like that Osram added something like wire or two to improve properties.
I see no problem in using it in FET DD setup but of course with low current cell .
And Barkuti. I vote for MOFSET DD Setup with Sanyo GA 18650 cell :+1:
That configuration will run 5.5A (at 4.2V) > 3.3A(at 3.4V).
New series of Osram seems to be very robust emitters. Soon you’ll see that there are emitters that can pull over 12A without burning led or angry blue
So yes i vote for FET DD configuration but with low current cell (there are plenty of them on the market). No need for spring bypasses any more, no need for stacking chips, so it is just a cheap - budget configuration at the place where Frugal meets flashlights
Nothing against linear or buck/boost drivers also. Just bring them on…
After all I use linear driver as a host for my nice little diy 1.5$ Djozz driver. Some guys like regulation while some really don’t have any need for that.
Barkuti this pic is just for you (I am preparing whole FET driver army )
It’s not though, the black flat was still better.
Unless you’re talking about how at a constant voltage the XP G2 will draw less current than a white flat and therefore not overheat as quickly resulting in higher performance.
But that’s not really a fair comparison here.
You’re basically letting one LED overheat and not the other.
The great thing about low Vf is that you can drive it at it’s peak performance for extended periods of time using a regulated driver instead of an inconsistent dim, bright, and dim that DD would give with an increased risk of killing the LED.
There’s really no reason to do DD anymore. Drivers that can supply more current than necessary already exist.
Ok granted I was being a bit unfair heat-wise in that it can take ‘sloppy’ abuse better for higher extended performance. BTW so the Black Flat can take DD generated heat (abuse) better than the XPG2?
