6th Annual Scratch Made Light Contest - Flashy Mike's machined project
136 posts / 0 new
Flashy Mike
Flashy Mike's picture
Last seen: 1 day 4 hours ago
BlueSwordM wrote:
@Flashy Mike, have you thought about using a TP5100 with a USB-c female breakout board like this:
https://www.aliexpress.com/item/DIY-24pin-USB-C-USB-3-1-Type-C-Male-Female-Plug-Socket-Connector-SMT-type/32746969779.html?spm=2114.search0104.3.60.3468408647cjzU&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_204_10130_318_10547_10059_10884_10548_10887_10696_100031_10084_10083_10103_10618_452_10139_10307_532,searchweb201603_60,ppcSwitch_0&algo_expid=63115a5e-4bad-4d07-a81f-9f0988b6913c-8&algo_pvid=63115a5e-4bad-4d07-a81f-9f0988b6913c&priceBeautifyAB=0
This would work very well for charging the lantern, as it is more efficient that the TP4056, supports higher charging voltages, and would work with a USB-C female breakout board without any trouble since the current draw is predetermined.
Will have a look at that, thanks!
FmC
FmC's picture
Looking great! Thumbs Up
Flashy Mike
Driver design is finished and sent to the fab. Two channels with 1×7135 and 6×7135. Has pads for my programming adapter, of course.
Will post new renders soon.
Phlogiston
Phlogiston's picture
Last seen: 4 days 16 hours ago
Oh, the light shields its own power switch when closed! Clever.
Flashy Mike
What I have ordered so far:
- SST-20 3000K high CRI LEDs on MCPCB
- o-rings in different sizes
- nylon screws
- circular neodyme magnets 20×2 mm
- 5mm RGB-LED for status display
All from China, I hope everything arrives in time …
MRsDNF
MRsDNF's picture
Last seen: 5 hours 43 min ago
Looking good FM. Beer
Flashy Mike
As promised more renders, also from the inside this time. I really love doing this renders, but I’m also afraid how the real 3d prints will compare to them. Perhaps there should be a category for virtual lights only … Wink
The lighthouse:
Bottom of the lighthouse with o-ring and cut outs for wires:
The electronic compartment in the lower housing:
The bottom plate with neodyme magnets:
Reflector with retraction system (hard to see in this renders but the reflector is slightly conical shaped):
Lantern closed (LED is RGB) …
and open:
DavidEF
DavidEF's picture
Last seen: 1 day 19 hours ago
Very nice renders! I agree, it’s gonna be very hard for you to compete with that. We need a new category. Silly
- The YKK Philosophy
MRsDNF
MRsDNF's picture
Looks amazing. You have certainly put a lot of thought into this. Thumbs Up
Flashy Mike
Yeah, designing this light was much more work than expected but I learned a lot about 3d design in the last weeks. Anyway, now I can take a short break until the ordered components arrive. I’ll double check all dimensions with the components before I start printing, don’t want to waste time and filament.
gisewhcs
Last seen: 2 days 4 hours ago
If this design works out well, I’d be happy to buy one or two!
Viel Erfolg damit!
(Kind off “best luck with that one!”)
Hoop
Hoop's picture
Nice project Flashy Mike. Sweet renders. Thumbs Up
DavidEF
DavidEF's picture
Viel Erfolg damit!
Honestly, his renders are good enough, even if he didn’t want to mass produce these himself, he could coordinate with a manufacturer like Sofirn and have them made. Wink
Agro
Agro's picture
Last seen: 57 sec ago
Reflector will point the light down and to the sides. If it’s only slightly conical-mostly down. It will hit the body and what’s next? If you don’t paint it white the light will be absorbed and lost. If you do paint it white, it will be reflected. Which may or may not cause glare.
Flashy Mike
Its absolutely possible that this project won’t work as expected finally. Wouldn’t be the first of my ideas. You’ll never know if you don’t try.
The concept might be new to flashlights but not to lighting in general: its simply a portable uplight which I like most for house lighting. I’m using orange pearl Convoy S2+ reflectors which are not famous for throw, so a lot of the light leaves this reflectors already diffuse. I guess a printed conical reflector isn’t even required. 3d printed top surfaces are not even at all due to the nature of this technique.
Of course there is a light loss but I’m less concerned about the light hitting the body after reflection than about the light passing the reflector at the side. To address this point I’ve positioned the light modules as near as possible to the center of the body.
Regarding the glare: you won’t see the reflector bottom when the light is standing on the table since your eyes are above. But you might see into the reflectors of the light modules in the housing which I like to avoid. In my prototype below with the Q8 I solved this problem with a tube which holds the printed reflector and shields the Q8 reflector. For the contest entry I consider to position the light modules a bit deeper into the housing. Then I would loose some of the spill of course. I have to find the best compromise.
To test this concept you could make a simple experiment, hold a piece of white paper over a tail standing light in a proper distance.
Here the prototype images, I will take another picture with the light in operation when its dark. The reflector is printed of white filament without any coating. I’m using this prototype regularly as a working light on my workbench.
Flashy Mike
Prototype in operation:
Agro
Agro's picture
Looks really good, though it’s quite a bit different optically. Both because the shims block light going sideways and because light that goes down towards the light hits reflector and has a chance of escaping up (though has a good chance of eventually hitting the shim as well).
If you’re not concerned about losses from the light hitting the body, I expect your light to work well. Thumbs Up
Flashy Mike
Last weekend I wrote a new firmware for this light (from the scratch, as required Big Smile ) and I’ m pretty satisfied with the outcome. It also includes the gimmick I announced in my first post, which hasn’t been realized in BLF before, AFAIK.
And I got some of the components but I’m still waiting for more parts I ordered in China. I should start with the printing within the next days since it will probably last several days for all components, even if everything works out well in the first attempt (what I don’t expect).
Flashy Mike
Btw. there is another board on the way, any idea what it is supposed to do?
DavidEF
DavidEF's picture
Uhh… nope! Facepalm
Flashy Mike
Got the boards this afternoon:
One more try? Wink
CRX
CRX's picture
Last seen: 1 week 5 days ago
That’s the spirit Smile
thijsco19
Last seen: 1 hour 31 min ago
RX TX? Maybe something with a transmitter and receiver setup?
DavidEF
DavidEF's picture
One more try? Wink
Nope. I’m still a dummy. The one on the left looks like a driver, but I still don’t know what the “new” board is. Facepalm
Flashy Mike
Populated but not tested yet:
Thijsco19, you are close.
DavidEF
DavidEF's picture
Okay, it has a trace that looks like an antenna. So, it’s a wifi module? Bluetooth?
Flashy Mike
MascaratumB
MascaratumB's picture
Last seen: 3 hours 8 min ago
Say wha? Shocked
I always love to learn with these mods/builds Blushing
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 / PT18pro / PT28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro / 311 / Z821 / i5 // ROVYVON: A2 + A5R / E300S / A8 / A23 / E200u // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 / E12R // XTAR: PB2 Charger // Mods: 1 / 2 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
Flashy Mike
Dang, just noticed the 7135 I used for this build are not best. They need a minimum pwm value of 10 to light up the 7 XM-L2 in my test head. Fortunately I provided a 3rd channel (resistor) for (energy saving) ultra low moon with sleeping MCU. Firmware needs a fix though in order to allow a smooth transition from 1st channel (1×7135) to second channel (5×7135) and vice versa.
pinkpanda3310
pinkpanda3310's picture
Last seen: 22 hours 24 min ago
That is some awesome creativity Thumbs Up
