Can I short a driver throught the AMC 7135 (lexel´s bistro FET driver)? (If there will be a contact of AMC with brass retaining ring = ground?) I don ´t completely understand functionality, in this case more like polarity of driver components.
Yes, I’m pretty sure that is possible. If one 7135 is shorted by accident then there should be a minimum of 0.350 amp going through the driver and the light will not go dimmer than this.
I took a quick look at MTN E to see what he offers on that driver with ATtiny13. Besides Bistro, you can use Guppydrv Dual if you have access to it. That’s all I know, sorry.
The correct answers are to take them to either a battery bin at your local hardware store or Best Buy, or to take them to your local household hazardous waste center
I used to do a lot of laptop cell pulls, so at one point I had a 10 lb bag of dead cells. The hazardous waste center wouldn’t take it, as they said they only took household waste. I said, “This is from a household, but I know what you mean.”
I ended up taking them to a Batteries + Bulbs, and they took the cells no questions asked.
I’m not sure what you mean by this, this CPF post is very helpful for making a decision on a lube. I use Super Lube on everything. I bought a big tube a couple years back and I haven’t even used a quarter of it yet. Not sure how easy it would be to get that where you are though.
