NovaTac 120T Triple Nichia 219C - H17Fx - 18350 - Tail Clicky
26 posts / 0 new
CRX
CRX's picture
Last seen: 21 min 54 sec ago
Stock Light:
Low - 40lm
High - 122lm
On to the moddin'...
There is no way these drivers will come out in one piece, had quite a job breaking it out as it is fully potted in hard black resin.
Aluminium heatsink filed into shape to fit the fit the internal contour of the flashlight head and make contact with pill insert, potted in place.
22mm brass tube cut & filed down to fit inside the aluminium pill with brass mounting ring inside for 17mm driver, all soldered to contact board.
2mm thick aluminium disc installed in pill. Copper contact soldered to driver board.
Another 22mm brass tube section cut for optic/ MCPCB surround to support O-ring, fitted in place.
Copper tape around pill for snug fit.
NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm.
Cut out slot for new clicky switch in switch board, soldered in place.
Brass ring soldered onto board, spring attached, wire bypassed, potted.
Felt lined battery tube. Reassembled.NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm.
NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm.NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm.Triple Nichia 219C D320 5000K on 20mm MTN DTP MCPCB
10507 Carclo optic
22mm x 2mm ARC glass
Cyan GITD glow disc
Dr Jones H17Fx driver
Reverse clicky tail switch
Lockout-able
18350 cell compatible
Length – 86mm
Width – 26mm
Weight – 96g (with 18350 cell)
I have it set up like this for the moment:
Mode 1 - M/L - Level 2 - 0.1% - 3mA
Mode 2 - 35lm - Level 12 - 3.0% - 95mA
Mode 3 - 260lm - Level 18 - 25% - 760mA
Mode 4 - 1010lm - Level 22 - 100% (8x7135) - 3040mA
Double Tap Mode - 2300lm - (Level 24)
Quick test:
0s - 2300lm
30s - 2117lm
60s - 1827lm (Hot!)NovaTac 120T - Triple Nichia 219C 5000K - H17Fx - 18350 - Rv Clicky Sw - 2300lm.
See Also:
NovaTac 120E Nichia 219B.
NovaTac SPA Defense SPL-120 - Nichia 219C 4000K - 18350.NovaTac SPL-120 - Nichia 219C 4000K - SD - 18350 - E- Sw - 435lm.
NovaTac 120P Triple Nichia 219C 4000K 90CRI H17-Fx - 18350 - Tail Clicky.NovaTac 120P EDC Triple Nichia 219C 4000K 90CRI - H17-FX - 18350 - Rv Clicky Tail Sw - 1800Llm.
Edited by: CRX on 09/10/2019 - 00:19
Coppet
Coppet's picture
Last seen: 14 hours 21 min ago
So I don’t know what to say, my Novatac just got fantastic LOL I really don’t have the words at the moment but that’s because English is not my mother tongue Wink But I’m thrilled what you have created, everything I wished for has been realized, perfect Thumbs Up Thank you very much!
CRX
CRX's picture
Cool Smile Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 58 min 41 sec ago
Impressive!!! Beer
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
weklund
weklund's picture
Last seen: 12 hours 50 min ago
Excellent mod … Smile I’m a long time fan of Novatac.
... Happy Landings ...
CRX
CRX's picture
Nice. What clips are those?
Coppet
Coppet's picture
…..I was just about to ask Smile
weklund
weklund's picture
Lower clip was made by Moddoo (Titanium Engineering). Excellent Titanium clip.
http://www.candlepowerforums.com/vb/showthread.php?283434-Titanium-Pocke...HDS-RA-lights
CRX
CRX's picture
Thumbs Up
Lithium
Lithium's picture
Beautiful mod.
Want DC-fix? PM me!
jon_slider
jon_slider's picture
Last seen: 3 hours 43 min ago
CRX wrote:
Stock Light: High – 122lm
Triple Nichia 219C D320 5000K: Double Tap Mode 2300lm
Thumbs Up , Beer
chadvone
chadvone's picture
Sweet job CRX. Coppet your very lucky, this is a great light.
Slayer1
Slayer1's picture
Last seen: 1 week 17 hours ago
Awesome build as always. Need to add a Novatac to my collection.
weklund
weklund's picture
jon_slider
I asked HDS if their clips fit a Novatac, they said no
Our current pocket clips will not fit the Novatac – the diameter is too small.  The clip ID is 0.930 whereas the Novatac requires an ID of 0.950.”
weklund wrote:
Novatac clip from Prometheus Lights … Wink
That is actually an HDS Clip.
I gave Prometheus the dimension of the Novatac opening, and asked if they would enlarge the hole for me.
They said no.
weklund
weklund's picture
They said no.
Oh well … sure looks like the clip from yester year. I had mine mounted on both my Novatac and HDS yet did not notice any slop in the fit. Seems like a little dremel tool action would open it up a skosh for the fit.
I stand corrected.
Thanks
toddcshoe
toddcshoe's picture
Last seen: 6 hours 26 min ago
Great mod CRX. Nice to see a Novatac with more output than a 2 dollar AAA light.
"Everywhere I go, there I am"
lumenzilla
lumenzilla's picture
Last seen: 16 hours 25 min ago
Wow, fantastic mod.
You have gifted hands, CRX.
jon_slider
weklund wrote:
…clip was made by Moddoo (Titanium Engineering) … I had mine mounted on both my Novatac and HDS
thank you for sharing info
that makes sense that your Moddoo Titanium clip for Novatac also fits HDS
the difference is only 0.51 mm and the Novatac version has the larger opening.
http://www.candlepowerforums.com/vb/showthread.php?283434-Titanium-Pocke...HDS-RA-lights&p=3467380&viewfull=1#post3467380
Moddoo wrote:
The difference in the clips is the size of the hole.
The Novatac clips have a slightly larger hole to allow them to fit over the slightly larger tail diameter.
You can put the Novatac clip on the RA/HDS, but the RA/HDS clip will not fit the Novatac.
It may take a little careful centering of the clip as you tighten the tail or head, but it will work fine.
You are very fortunate to have one of the discontinued Ti Moddoo.
I agree a little dremeling could adapt an HDS Clip to fit a Novatac
A design similar to the Moddoo clip, called the decorative clip, is sold by HDS, in both Silver and Black, but not Ti
Unique Titanium also sells the Black decorative clip, plus a Titanium option that looks similar to the Prometheus Lights version.
The Clips with the hole that fits HDS are available:
black decorative: https://uniquetitanium.com/products/edc-decorative-pocket-clip
black and silver decorative here: https://www.hdssystems.com/Products/ClipCDS/
Titanium from Prometheus Lights aka darksucks.com : https://darksucks.com/search?q=hds
Titanium also here: https://uniquetitanium.com/products/edc-titanium-clip
jon_slider
fwiw, I believe there are 120E in stock here
Im not affiliated, just sharing info
here is a review that explains some of the differences between a 120T and 120E
http://www.woodsmonkey.com/novatac-120e-and-120t-review
I believe both can be made to behave like a Programmable 120P, using the 250 click back door. Im happy to help unlock Novatacs, if needed, PM me.
Slayer1
Slayer1's picture
Thanks, Jon for the info.
kevinm
Last seen: 2 weeks 5 days ago
Cool build! I’m trying to do something similar with mine, but I can’t get the red pill cleaned out! How did you get the potting compound out?
CRX
CRX's picture
Heat & a flat screwdriver.
I hold the pill with insulated grips & blast it with a dual jetflame lighter to soften the compound then dig it out.
Do it in a ventilated place & don’t inhale the fumes, unless you want to.. Big Smile
kevinm
Modding high AF! Smile
Thanks, CRX. I’ll give it a shot.
Arcadefreak43
Last seen: 3 weeks 5 days ago
Are these still available for Novatac?
jon_slider
No
I sent you a PM with more info
