I wasnt trying to compare difference between 40T and 30T. The replacement driver did absolutely nothing. I couldnt fet tje reflector out to replace the wires. The reflector is glued tight. I will try playing with the retaining ring
If I double click to Turbo I can’t hold to ramp down, I first must click to return to previous mode or press & hold switches it off. If Turbo is reached through ramping then it behaves as expected. Also while on Turbo any additional double presses causes a drop and fast rise to turbo again. It shouldn’t do anything if already on Turbo.
It’s seems to be designed to give a smooth ramp up to turbo over a second or two when double clicked. There’s not much of a need to double click if you are already ramped to the top, so that shouldn’t be an issue. I do prefer an instant jump to turbo. I’m not sure why they did this.
I haven’t tried to ramp down after double clicking to turbo. I guess I haven’t needed to. I usually use it at a lower level, then double click to turbo for a very short time then single click back to the memorized level.
No UI is perfect. If it’s really bothersome, Lexel should be offering some 21mm drivers soon. A 20mm will fit if you modify the retaining ring. Then you’ll have some other UI options. :+1:
Thanks Dale! Got bored during a 24hr machine endurance run and the shop lathe was in the isle next to it. Didn’t notice the plant manager was standing behind me, he’s like a Ninja, scared the hell out of me, when I heard somebody say behind me…wow that’s beautiful… I jumped he jumped He’s cool, borrows lights from me all the time, needs to buy a couple the money he makes…… :money_mouth_face: I let him borrow it the weekend before opening day, he brought it back, this is way too much light for me, got anything smaller? He loved the MH20GT… sent him a link and code, he can get his own.
Agree, that C8F 21700 treatment is awesome! I got 351D 4000K 90 CRI's is my first 21700 host, just ordered a 2nd host. Really like how the XPL HI V2 5D's look in a triple, probably will do them in the next. Ohh - just noticed Richard is low on them - order 6 of last 8 just now...
According to the markings (2D030L) the old one is the NXP PSMN2R0-30YLD, which has a Rdson of about 2mOhm. That’s already really low. No way changing that to any other FET could gain 2 Amps, except the 2D030L
- is fake,
- is defect or
was soldered badly.
But I assume you found the real flaw with the retaining ring. And I lift my hat for that, because that would be a design flaw that’s very easy to overlook.
My fix would be to file down the lower part of the threading of the retaining ring in a 45° angle, so that enough threading is left but the ring can sit lower. That should give good contact.
I have a C8F v2 host I ordered right when they first became available. I haven’t managed to finish building a light with it, but I check the driver I plan to use with it for fit. The PCB is one of the Oshpark 2oz copper boards, which are really thin (0.8mm). The retaining ring clamps down nice and tight.
So, bad driver/ring fitment may be a problem for some lights, but not all of them.
Regarding the “filing down the lower part of the threading of the retaining ring” — may I request a photo or illustration of which part should be done? Sorry, I’m not really into modding and have not-so-good skills but would like to see if that can help the relatively low amps on the C8F 21700. Thank you.
