I suppose it’s just a matter of scale - if I was ordering a good number of $10 cells from Illumn for example, then shipping costs starting around $20 wouldn’t be such a bitter pill to swallow.
It’s just a bit tougher when I’m only looking for a couple/few batteries; I was hoping there might be an acceptable alternative I could try out so I don’t overspend on this hobby from the get-go.
I guess it is what it is and only you can assign a ‘value’ to what you’re buying?
I just bought a Victorinox Ranger SAK off of Ebay and the guy wanted $6+ shipping, which was fine. He’s also been selling the bigger SwissChamp for more money, but a couple of dollars less for shipping, even though it’s a heavier item—both can fit in a small packet, or flat rate box.
Oh well…
Chris
My only experience with sofirn cells are one supplied with their lights and they have performed well.
JasonWW tested the 21700 Sofirn in the C8F and it performs well. I think I recall someone said the Sofirn 3000mah or 2800mah battery might be a rewrapped Samsung/Sony.
14500 discharged 855mAh on Li500, happy with that.
Ordered SP33 with 26650 kit to test that. Getting a load tester in 11.11sale to test both A & mAh
21700 & AA NiMh on a separate order
Same comments as you’ve already seen - I’ve received a few Sofirn batteries when buying a “flashlight and battery” package and those batteries perform as expected and test to capacity in my Lii-500 charger.
I have about 10+ Trustfire flame batteries still working, from year 2010/2011. I use them for my lasers, XP-Gs and XM-Ls.
They need to be legit Trustfure cells though.
I’ll also comment on the Sofirn 4000mAh flat-top 21700 which is correct capacity and has good IR. (I can only buy Sofirn battery with their flashlight [AliExpress — I’m in Asia], as they do not ship bare batteries to my country… although just very recently some Sofirn batteries from AliExpress seem to be “shippable” to my country now, but I have yet to test that option, it has some shipping fee, and the item description for the battery seems to indicate that they are still not definitely sure if batteries can be shipped to some countries…
For the other Sofirn 3000mAh 18650 (also bought as flashlight+battery kit), I previously tested their Sofirn 3000mAh (on the label) which turns out to be around 2800+ mAh only (despite the 3000mAh label). The IR measurement is definitely not as good as Samsung 30Q or Sony VTC6.
On a more recent Sofirn 3000mAh 18650 (also bundled with Sofirn flashlight battery kit), I tested the battery to now be 3000mAh. IR is still not the same as 30Q or VTC6.
The blue-black Sofirn 2800mAh 18650 (also bundled with Sofirn flashlight battery kit), these are correct at around 2800mAh, and they are protected 18650s (trip at around 6 amps).
I’ve also tried the Sofirn 900mAh 14500 (bundled with Sofirn flashlight), ordered in 2 or more separate occasions, they register around 850mAh capacity. The earlier Sofirn 14500s are shorter button-tops, while the more recent Sofirn 14500 are about as tall as other brands button-top 14500s (unprotected).
I just got the new SP33 which came with a 5500mah 26650 battery. I can’t find out much about the specs of this battery. Has anyone tested it or can point me in the right direction?
These 18650’s tested to be very good cells up to 7A continuous discharge current.
Equipment used - West Mountain Radio CBA lV
Sofirn’s datasheet specify the capacity as 5000mAh. Buyers have shown tests of approx 4700mAh
What tester did you get? I used the Lii-500 until learning it wasn’t testing properly on every cell. It gives a rough approximation.
I recently received the West Mountain Radio - CBA IV and it’s excellent.
I used to think my Samsung INR18650-30Q’s were fake on the Lii-500 as it was reading 2840mAh at 500mA discharge. Tried it on the CBA and it’s 3027mAh at 600mA & 2968mAh at 10A. Big difference
This also what I’ve heard. They are also not high drain cells. Just generic middle of the road cells.
Yes, their 4000mah 21700 is really top notch and high drain.
I don’t know much about their 18650 cells, but they are definitely not rewrapped name brand units.
Their black 3000mah 18650 seems to be really good. It’s a high drain cell “close” to a Samsung 30Q, but not one. DB Custom got really high output and amps from it.
So I only know about their black 3000mah, black 4000mah and black 26650. All the other versions I don’t know anything about except they are low cost.
Illumn is mainly a USA seller. What country are you in? Have you checked with NKON? Do Banggood or Gearbest ship to your country?
Here is a test at 5A for the Sofirn 3000mAh (Black), Panasonic NCR18650GA (Red), Samsung INR18650-30Q (Pink)
As you can see the Sofirn performs almost equal to the GA.
Here is a test at 5A for the Sofirn 3000mAh (Black), Panasonic NCR18650GA (Red), Samsung INR18650-30Q (Purple)
Interesting, thanks Funtastic. . :+1:
That is more voltage sag than I expected. So not quite as good as a 30Q. I wonder if it is still the same battery that DB Custom tested almost a year ago.
I have 4 of the Sofirn 21700’s and although they seem to be decent cells, they under perform. Fully charged, I put one in my FF E07 and turbo mode didn’t seem that great. Put a Samsung 30Q in, and turbo was noticeably brighter. In other words, they can’t handle the amp draw. Tried with all 4 of the 21700’s, same result. They act like a 10A cell. Ordered some Samsung 30T’s for the E07 instead.
In my next order of Sofirn lights I’ll get some 21700’s and 26650’s for testing and upload the graphs.
I may just start my own thread showing results for
14500 900mAh
18650 2800mAh PCB
18650 3000mAh
21700
26650
That should help those who are on the fence about getting them bundled with their lights.
