NovaTac 120T Triple Nichia 219C - H17Fx - 18350 - Tail Clicky
……I was just about to ask :slight_smile:
Lower clip was made by Moddoo (Titanium Engineering). Excellent Titanium clip.
:+1:
Beautiful mod.
:+1: , :beer:
Sweet job CRX. Coppet your very lucky, this is a great light.
Awesome build as always. Need to add a Novatac to my collection.
Novatac clip from Prometheus Lights … :wink:
I asked HDS if their clips fit a Novatac, they said no
Our current pocket clips will not fit the Novatac - the diameter is too small. The clip ID is 0.930 whereas the Novatac requires an ID of 0.950.”
That is actually an HDS Clip.
I gave Prometheus the dimension of the Novatac opening, and asked if they would enlarge the hole for me.
They said no.
Oh well … sure looks like the clip from yester year. I had mine mounted on both my Novatac and HDS yet did not notice any slop in the fit. Seems like a little dremel tool action would open it up a skosh for the fit.
I stand corrected.
Thanks
Great mod CRX. Nice to see a Novatac with more output than a 2 dollar AAA light.
Wow, fantastic mod.
You have gifted hands, CRX.
thank you for sharing info
that makes sense that your Moddoo Titanium clip for Novatac also fits HDS
the difference is only 0.51 mm and the Novatac version has the larger opening.
[QUOTE=Moddoo]The difference in the clips is the size of the hole.
The Novatac clips have a slightly larger hole to allow them to fit over the slightly larger tail diameter.
You can put the Novatac clip on the RA/HDS, but the RA/HDS clip will not fit the Novatac.
It may take a little careful centering of the clip as you tighten the tail or head, but it will work fine.[/QUOTE]
You are very fortunate to have one of the discontinued Ti Moddoo.
I agree a little dremeling could adapt an HDS Clip to fit a Novatac
A design similar to the Moddoo clip, called the decorative clip, is sold by HDS, in both Silver and Black, but not Ti
Unique Titanium also sells the Black decorative clip, plus a Titanium option that looks similar to the Prometheus Lights version.
The Clips with the hole that fits HDS are available:
black decorative: https://uniquetitanium.com/products/edc-decorative-pocket-clip
black and silver decorative here: HDS Systems: Accessory: cClipCDS
Titanium from Prometheus Lights aka darksucks.com : Search: 1 result found for "hds" – darksucks.com
Titanium also here: https://uniquetitanium.com/products/edc-titanium-clip
fwiw, I believe there are 120E in stock here
Im not affiliated, just sharing info
here is a review that explains some of the differences between a 120T and 120E
http://www.woodsmonkey.com/novatac-120e-and-120t-review
I believe both can be made to behave like a Programmable 120P, using the 250 click back door. Im happy to help unlock Novatacs, if needed, PM me.
Thanks, Jon for the info.
Cool build! I’m trying to do something similar with mine, but I can’t get the red pill cleaned out! How did you get the potting compound out?
Heat & a flat screwdriver.
I hold the pill with insulated grips & blast it with a dual jetflame lighter to soften the compound then dig it out.
Do it in a ventilated place & don’t inhale the fumes, unless you want to… :smiley:
Modding high AF! :slight_smile:
Thanks, CRX. I’ll give it a shot.
Are these still available for Novatac?
No
I sent you a PM with more info
