Iām not sure what happened to Captain Murdoch after the 80āsā¦ I heard he immigrated somewhere :disguised_face:
Lol - thatās probably closer to the markā¦.
Very nice start FmC, glad that Jack is back on board on this yearās build! That composite stuff is great, I have some in orange, a leftover from a building site. It is a pity you can not get it easy.
:+1: Cool!
Pics are good now, and everything looks like itās coming together nicely, in spite of Jackās help! :smiling_imp:
People here are so devilishly clever. Scary sometimes.
Great work, keep Barbie out of the picture or Jack will never finish in timeā¦
Good luck with the build, Jack !
Why use 219As? Iāve never seen those emitters used in a light before. Granted, Iāve only been in the hobby for a couple years. I think they were obsolete by the time I started.
perhaps they were already on hand??
Itās what I had lying about, plus they are renowned for a nice Rosy tint, which Jack is fond ofā¦
Nice progress wee man :+1:
I find it amazing the sheer work that goes into setting up pics of Jack at work as compared to the work going into the project itself. Well done! So well thought out and an incredibly interesting way to go about it!
What do you mean by setting up pictures of Jack? :person_facepalming:
You know, getting the pics without disturbing his work, tricky doing that. Most talented artists do NOT like having their photo taken at work. Disrupts the flow or something, they say.
So you have a 12 Volts Solar panel to charge 4x 3.7 Volts parallel batteries?
Yes, the panel will have higher Voltage when there is no load.
Once you start drawing current (load), the Voltage will drop.
Too much load and the Voltage will be lower than specified.
Maybe i missed it, but i assume you will be using a buck converter to go from 12 Volts to 4.2 Volts?
Iām using these USB step down modules;
Hereās the Panel Specs;
Maximum Power(Pmax): 10W
Maximum Power Current(Imp): 0.56A
Maximum Power Voltage(Vmp):
18.00V
Open Circuit Voltage(Voc):
21.5V
Short Circuit Current(Isc):
0.62A
At only ~10W, itās not a powerhouse, but should provide adequate charge throughout the course of a day.
Okay, step down from panel to 5 Volts.
And after that? A charging circuit?
That will eat up some power too thoughā¦
But it will work.
But i think you only need charging termination.
The current at 10 Watts to 4.2 Volts is only 2+ Amperes.
So thereās no real need to regulate the charging current.
As long as it stops at 4.2 Volts.
Jacks playin with ya. Thats why there isnāt enough current.
