On link picture showing light distance 300-500m underwater!
Don’t buy this shitt.
Hehe I already have the similar light but with the 15-led configuration. It’s a wide-beam flood type light and of course the promo/spec sheet is chinese nonsense. But it’s bright and has an insane angle, so that’s what I was looking for. Just wondering if the ones with the 6-led configuration are even brighter perhaps!
The LEDs are probably ok in output even if they are the “chinese equivalent” stuff, go search here in BLF for the Rome Asahi Q30 thread, the light is supposed to be 3 x 70.2 but instead it’s chinese 7070. Even then, it’s decent output for that light for the kind of price (i was able to get it for just usd 44 or so, but still not low enough i was aiming for like usd 35 ), 7-8k lumens in a ceiling bounce, even if it isn’t a 21k lumens Haikelite MT09R. For sure you can push 7-8k out of a single Cree 70.2, but i am pretty sure that your lm/W efficiency would be way worse than even the “nasty” chinese LEDs.
All these stuff is really dependent on the driver and how much it’s pushing, coz as we all know you can run 50k lumens in a 1kg light underwater and there still would not be an overheating issue for the LEDs.
So 6 pieces, 15 pieces of the LED in the light it’s going to be the same thing unless they do spec a higher power driver/more batteries in the bigger light with more LEDs, then would it make a practical difference in real life.
And i suppose if you are doing some videography as well then the tint is reasonably important.
You might find some pictures in the reviews section in the links below to give you more info for reference.
I read that it’s about 6000 lumens in reality in one user review, so i suppose it wouldn’t be a 1000 lumen light.
At usd 37 for the links below, i think it’d be difficult to ask for more from the price. If you want more light, go for 2 or even more, nets you longer runtimes as well.
There seems to be another version. Chinese LEDs definitely.
Obviously there is some sort of typo ;-) in those figures.
Totally smells like out of order light quality in those torches, could it be?
Cheers :-)
I had such light and it leaked on a first shallow 15m dive.
Salt water killed everything
It’s a lottery, some of my friends use it and they are happy….
So, did you have fun? Maybe some teflon tape…
What is the actual effective throw of it? Not now, I mean, when O:) working. 15 meters?
Same trouble here. My leaked after 5 dives.I was able to save mine and found the the switch is poorly designed and allows water in.
I bought another light 6LEDs 9090, slightly different body style , more like one pictured with camera on previous post, and I took the switch apart and noticed that this light has improved switch. They added another silicone membrane to stop water from ever coming in contact with button shaft.
I use two of these , have about 40 dives with them up to 30m and so far so good!
Very bright, but fairly small and in comparison by far cheapest out there.
I am looking at https://www.amazon.de/dp/B07FTHDDXN/ref=cm_sw_r_cp_apa_i\_.rDoEbNPY39F9
I see that theres a link to taobao but i can’t translate reviews… Is it worth 60€?
RokSiEu, that looks like another leaky piece of junk with overstated specifications waiting to make your day.
I would rather buy a flashlight designed and built by a real manufacturer. Sofirn has many diving torches, for example (but better look for reviews before buying, like this Sofirn SD05 review by Nachtfeuerzeug). ThorFire, another nice brand, has its ThorFire S1 diving flashlight recommended at GloboSurfer as a best pick.
Anyway, feel free to ask but wait for more experienced users in these concerns to chime in.
If you are looking for powerful light with wide angle beam , check the link below. I bought two of these and have about 60 dives with them and so far they perform well. Very reasonable price
Is it blue or UV?
Do you have some pictures or videos taken with those lights? Can it be mounted to gopro holder?
Try this link , all details are listed .
I used model that has 6x 9090LEDs , those blue/uv leds really work for corals with neon colour.
Video taken with these lights.
They have 1/4in tread so you can fit attachment to suit your need.
Rec diver, your above #15 post includes a link full of unnecessary tracking information, all which comes after the question mark and the question mark itself is better removed.
The link can in fact be further simplified by removing the information between the itm string and the article number:
https://www.ebay.com/itm/-/233224259249
However, the reason I'm telling you this is because the excessively long link you posted breaks the forum page layout, as it exceeds the thread box. Could you please edit your post and replace that link with one of the above? Thanks.
For illustrative purposes:
Amazing video, which camera are you using?
Panasonic GH5
Sorry, link fixed. I hope it still works.
It does, tnx for the tip, now I’m just thinking if I should go for the one with more LEDs as most of the dives are done in mediterranean sea where we don’t have such great light conditions as in Carribean
I do believe that the 6x9090 LED model produces more light ( they claim 500W, probably less but very bright)
The light you were referring in your first post have 15 smaller LEDs but they rate these (120-180W equivalent) which would mean a lot less light produced. The 9090 LEDs are some of the most powerful out there.
The model with six 9090s have burning time 45min at full brightness with good Panasonic batteries.
With three modes you can easily adjust desired brightness and on low batteries will last more than 80 min.
