Fitorch MR26 XHP-35 LED 1800LM 6Modes 3-Way Tail Switch IPX8 Waterproof LED Flashlight 18650 Battery
Coupon code with nice discount is available.
» Request via PM here«
I got mine in a couple weeks ago. It seems to be a not so great light, which is what I expected. The Bistro UI is quite interesting though. That was one reason I bought it.
I measured 810 lumen with widest beam and 270 lumen with narrowest beam. The driver seems to step down very slightly every 10 to 12 seconds which is very odd.
The Vappower 5200mah cell seems to be quite a low powered unit. Pretty much equivalent to the Keeppower 5200mah. About a 10A continous cell. Review here.
The Xanes are actually protected. They seem to trip at about 3.5A. I didn’t check capacity but believe they are 1600-1700mah as reported earlier.
I switched off the thermal calibration thingy and this step down disappear. I believe manufacturer didn’t do or did very bad thermal calibration for it.
I didn’t try to calibrate it though.
I’m still waiting on mine to arrive…
Haikelite Q30 7070LED 12000Lumens 5Modes Charging Indicator Light IPX8 Waterproof LED Flashlight
NITECORE MH25GTS XHP35 HD 1800LM 8Modes USB Rechargeable LED Flashlight + 3500mAh 18650 Battery
Coupon code with sizeable discount is available.
Nitecore MH12GTS XHP35 HD 1800LM 5 Brightness Levels 3Modes USB Rechargeable LED Flashlight 18650
NITECORE EC4GTS XHP35 HD 1800LM 8Modes Unibody Compact Long Thow Searching 18650 Flashlight
Coupon code with very nice discount is available.
Wuben E05 XPL 6Modes 900Lumens Magnetic Tail EDC LED Flashlight Reading Light with Diffuser 14500
Coupon code with very good discount is available.
Use coupon code BGRTW to get $12.99 price ($19.99 / –35%).
Neutral white and cool white options available, accepts 21700 cells.
Lumintop BLF GT mini XPL HI 1200LM Stepless Dimming Portable EDC 18650 LED Flashlight
Use coupon code AC18 to get $34.65 price (-$14.85)
Offer valid until November 24th.
4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery
Use coupon code AC18 to drop the price to only $15.39 (-$6.60 / –30%)
These are ideal (and recommended) for BLF Q8 and other high power lights.
Offer is valid until November 24th.
4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery With Protected box
Use coupon code AC18 to get $16.09 price (-$6.90 / 30% off).
This cells pack include plastic protective box and therefore can be shipped to more countries than bare cells.
Ideal (and recommended) for BLF Q8 and other high power lights.
That’s a good deal. I ordered!
I’m in California and it says they can’t ship these cells to me?
Did you try to order the ones in the plastic case?
‘user’ error, my bad. Works now. Thank you.
Convoy S2+ Nichia 365nm UV UV LED 1Mode OP Reflector Flashlight
Use coupon code AC18 to get $20.26 price (-$8.69 / –30%).
