It’s a triple heatsink, though I have a program for singles also. The white flats should work with this kind of setup but not the black flats. Black flats are basically obsolete now though.
Good thinking Dale. There will need to be a provision inside of the pill which will allow it to be turned out. The ret ring would unscrew, then the driver turned sideways, then removed via inside provision.
I made a duplicate copper pill for my Jaxman Z1 and made it a bit more robust, I think it really helped in the light I built it for and it needed all it could get as I had an SBT-70 in there making a lot of heat. Pretty straightforward build really, I don’t know how many Hoop would sell or if it’d be worth the programming time…
Kawi, you mean that the Cometa is NOT a Jaxman Z1? Sure thought it was, even read something recently about that very thing. Me and my memory. Sorry about that teach…
Edit: Ahhh, the Cometa was a Manker clone of the Jaxman Z1….
