Oh boy, on the stock 2600 cell @3.8V, turbo does ~600 lumens, but with a 4.08V BT 30Q, ouch!! Beam center starts turning blue and lots of heat, but modes work fine, so don't think there's a direct short or something with a 30Q in there. The driver appears to be in the tail on a 16.8 mm PCB with the small e-switch mounted in the middle - bad news for modding, unless there's some custom work, or something else to work around this design. On the DMM, I read 51 ohms between the brass button and the outer shell of the head - interesting... I'll upload pics now...
Maybe it’s just tweaked for the high resistance stock cell. I’l charge it up and see.
The black plastic may be a little unclear. Looks like tweezers could fit in slots around the brass button. I tried but could not budge anything. Maybe what I would try is drilling 2 holes in the plastic, then see if i can get some leverage with a needlenose or other tool. The head is one piece, least appears that way - mp removable bezel.
On the stock cell fully charged and on turbo, output starts turning strange colors, blue I think.Other modes are regulated and work fine. With the cell as shipped at 3.8V, turbo works fine but only ~600 lumens. Dunno if it's just my unit or a driver problem, or something...
My blue beam tint problem went away after I heard/felt a 'pop' in the head area. Weird - still gets very hot and output drops hard in the first 30 secs: 626 lumens at start, 476 lumens at 20 seconds. These #'s are way lower than specs. I measured "hi" mode at 273 lumens, med=157, lo=73, lowest=16, moon=0.6
Specs say 900-300-150-50-10-0.5, so in the ballpark but turbo should be at 30 secs, which is probably ~450, 1/2 of what they spec'd.
Wish I knew what that 'pop' actually did -- interesting.
Nothing I can do to mod this, unless someone does a driver PCB design for it, even still, space for parts is tight because of the switch, and the other issue how batt+ and batt- are handled.
That’s my plan. How does the driver / switch actually work? How does the signal get to the driver in the head? Is the method used suitable for narcelM (i.e. can the tail button trigger like a standard e-switch press for the FW or would it have to be custom everything)?
Too many dunno's. Can't get the head apart so dunno what's there - think the driver is the tail board in the pic above. Uses a small 20 pin quad pack MCU. I assume for LED power, batt- goes thru the body up to the head.
16.9 mm. Think I mentioned that I measured 51 ohms between the brass button and the head shell, so, there's some connection there. I was think'n it's something like PD68's tailcap LED's. There's no other wire running head to tail so it must be using the battery tube shell.
This is also weird. While testing, in a higher mode, think turbo, I heard/felt a 'pop' coming from the head which I really thought was the LED blowing the silicon bubble, but instead, the blue tint shift went away! It still gets hot quickly on turbo, but the tint shift issue is no longer. Didn't notice any physical damage to the LED either. Wonder if maybe it wasn't reflowed properly, then the heat melted the solder some what and re-seated the LED better on the pads. A bad reflow can cause the tint shift, from what I thought.
Even though in the initial use of the flashlight I didn't notice any angry blue, this evening after turning it on I indeed saw that the tint turned blue after staying for a couple of seconds in Turbo.
So TomE , it seems that there is something clearly wrong in the flashlight in general.
I shall send a message to Fomolov to let them know about the issue.
Did'n't check specs, but yes, seems like the 219D is low Vf LED, so amps can go crazy. That pic I took of the tail PCB certainly appears to be everything a fully working driver needs - I'm assuming that is a full driver, and at the head, is probably something simple like a resistor or something, no smarts. Got a couple of 18650S owners over on FB (Flashoholics Anonymous group) saying they don't see the blue shift on turbo on full charge, but mine is not showing that now as well. May have to risk an attempt to get the head apart.
Out of the box quite nice. Great fit and finish and nice compact size. No sign of blue-shifting tint when I used the partially charged cell that came with the light.
But then I used the built-in USB to fully charge the folomov cell and PROBLEM!!! When turned on in turbo the light blue-shifts within 5 seconds and output drops dramatically. Instead of 800 lumens it looks like its only outputting 100 lumens.
Once the light is warmed up by having been turned on and off for 5-10 seconds, the problem is worse. Turning the light on while it is warm causes the blue shift and reduction in lumens to happen almost instantly (less than 2 seconds).
and all of this is with the cell that came with the light! It’s not even a high discharge cell I assume.
My guess is the LED simply can’t take the amps. Either that or the LED is defectively installed. If anyone can get the head open it might be worth swapping the LED to something else. Perhaps XPL HI.
The most interesting thing about this light seems to be its tail-mounted driver with no extra channel to run BAT+ back or run the switch signal forward.
How does that work? Does it seem like something which might be useful for BLF designs?
