I decided to order a couple of purple from BG. They state they have Nichia 219B. I know some have had problems with BG, but I haven’t and would probably write it off and never again if PayPal would not get me a refund. I do not buy much from BG.
That light and color are really cute.
Jerry
These the ones that got NMM?
I got a coupla waaaaaaay back, no NMM, but later(?) versions seemed to have it.
Yeah, you want one of the first batch (Manker driver)
But then still it kind of sucks a little…
Threads are too sloppy / loose, starts in unusable firefly mode… (i mean, come on, it’s like 1 lumen or something…)
The later models have visible PWM on low modes i.i.r.c.
I would even prefer a 1 mode Olight i3E, although the Nichia in the A01 is okay, but again, not as nice as the first batch…
Or spend more and get the real Manker.
Sounds as if there is anodizing inside the tube, which should have been drilled / milled out.
Maybe you could grind the bottom out a little, if you have a Dremel of some sorts and a long grinding bit.
But maybe interesting to go to Gearbest and look for the BLF 348 with Nichia LED.
https://www.gearbest.com/led-flashlights/pp_554387.html
Only one mode (ON), but it’s stainless steel and a timeless design.
I had one of the BLF 348, and also a Slingfire. Personally I preferred the Slingfire to the BLF model. The tint did not do anything for me.
AliExpress has a sale coming up on some Lunintop Worms in a couple of days. I will pick a couple of those.
https://www.aliexpress.com/item/LUMINTOP-Mini-Worm-AAA-110-Lumens-Keychain-Flashlight-with-clip-1X-AAA-Battery-Cree-LED-Tool/32736465729.html?spm=a2g0s.13010208.99999999.260.41433c00hivyb3
Thanks for the reply.
Jerry
I just got a couple for $6.96 shipped. The code says black, but it worked for an orange and a red one. I had to buy one at a time.
I also got the first batch when it came out. It was not reliable. It either skipped modes or stuck in Med mode refuse to go to High mode. I tried with primary, lithium, and rechargeable (eneloops and amazon basic). I gave up and just toss it in the drawer.
I carry a green one daily; it’s been dropped and banged around; still works fine.
I had trouble with the first black ones I bought. I would have to reemove the spring and re-insert it with the battery. Did not have ths problem with purple.
Thanks! just ordered one. i already have one and i think it is almost the perfect edc. o-ring broke off and i cant find the spare so now i get a light and can use the spare oring. hopefully it doesn’t come with NMM that my first one did.
What is NMM?
Next-Mode-Memory
I just got a couple — it’s the no-name driver, but has the 3 levels and hidden strobe.
One of them works fine; the other is intermittent, skips brightness levels, flickers up and down.
No wonder they were on sale.
Mine has sometimes disease too. Sometimes it works right sometimes it don’t. You never know what you are getting with it. It’s like playing the brightness lottery. You know it will light up, you’re just really not sure of the outcome. It has been relegated to a bathroom emergency light. I’d give it away if I wouldn’t feel so guilty about it.
got 3 last week. opened them up to do the pencil trick today. took 10 minutes for all 3 lights. Happy with the outcome. All lose memory after 3 seconds and return to firefly. before that with next mode memory as they came, they were basically unusable and a PITA. Now an instant favorite.
not sure if a 8$ light is acceptable if it has to be modded to work as it should… but now mine is good.
it is probably frustrating for a lot of non knowing people to get the brightness-lottery whenever they turn these on. I would never ever bought these lights if I had not read that I can hack them with a pencil to make them work like the original design.
I made a little hook out of paperclip, fished the spring out from the A01 battery tube, dabbed a little conductive lubricant on the wide end of it and pushed it back in place. That seems to have resolved the flickering problem. Probably if I’d looked I’d have found a sharp cut end on the spring that was making intermittent contact with the base of the battery tube.
It’s the cheap little corner-cutting parts that screw up the product.
No, I sure didn’t. It just really wasn’t that important to me. I bought it mostly because the wife liked the color. She swiped up a BLF348 instead. So it doesn’t really get used anyway.
did you “try the pencil mod”:Astrolux A01 next mode memory removal - Album on Imgur?
I greatly appreciate the pointer, very helpful.
That’s a good price - where did you order them from?
Are they Nichia 219b (or c?) and are they ‘always start on low’?
I regret not buying more from the first batch, I’d sure like to get my hands on a few more.
As others have stated, they are next mode. Too bad, great light and perfect for my use otherwise… but the “NMM” completely ruins it for me. I prefer M-L-H but can work with other similar interfaces as long as its no memory.
Just did the pencil fix on one of the two I just got. Perfect behavior now.
I’d like a word with the subcontractor who provided the wrong resistor to the builder (or the purchasing agent who found a great price on “almost close enough” parts).
