Low-cost copper pills, spacers, optics, drop-ins (Updated 23/10/2022))
Planning is a too big word…
I have a copper A01 BLF edition. It is “that dim light”. Dim, heavy, not my taste at all. But a hefty copper host….would make a fine hot rod.
I’m contemplating 2 builds.
One that is tempting but too impractical: XHP50.2 K2 3C + 2*10250 Nukes + QTC.
The other that I might actually attempt: LH351D + 10440 + QTC.
Or maybe even less practical. May not fit. XHP50.2 6v+3s10180
I’m pretty sure neither the 2x 10250 nor the 3x 10180 will fit. Unless you know something that I don’t. :question:
EDIT: I wonder what it would be like if you put the OSRAM KW CSLNM1.TG “white flat” emitter in there. It’s a 3V emitter, and the current “throw king” according to the testing.
Dunno maybe it wouldn’t. But the stock driver is very thick. And I have a similar construction by CRX in a Thrunite host, so that was an obvious inspiration. 3s 10160 is an option too. :wink:
White Flat would need a SMO reflector to really perfofm. And bezel is quite thick. Though low Vf is interesting. Anyway, not for me, I want a pee light, ideally with 1000+ lm. :wink:
Just received two Copper P60 Quad shells. Excellent quality as always, awaiting parts to build with.
Yeah, dunno if I mentioned this when I got ’em, but the pills for S2+ triples came in perfectly, nice sturdy box to hold everything, and shiny! :laughing:
Just received my S2+ copper pills. Thanks!
Hi Kirill, do you offer Convoy C8/C8+ retaining rings?
Im sorry I cant find C8 pill ATM.
Does C8 rings interchangable with S2+?
Have you started a batch of copper S2+ full triple pills yet?
Sorry, dont see it reasonable since Hoop’s pills will be available soon.
Do you have a link to Hoop’s pills please?
Thank you kind sir.
Received a large order from Kiriba-RU. Everything looks good as usual. :+1:
I just, quite accidentally found out about the existence of “C8TT”. This is very, very cool!!
Do you have more details about this? It looks really nice, but i don’t see how to use it
Im building big belt grinder. It took very long time, same time Ive made a batch of parts that allow use angle grinder as belt grinder. I could not wait longer to try 3M green belt in some difficult job so I temporary set my battery powered angle grinder as belt grinder and tried to sand flat C8’s stainless bezel. Tiny machine dont work as good as big one but anyway it didnt take much time.
Regular SS C8 bezel sanded flat with some laser engraving. How to use it? Probably will make another one for special C8TT set for 2k post GAW.
I’d be in for a flat one
