Yes, it would need to be re-aligned but honestly I think it would be very hard to align it seamlessly. So I think grooves to partition each knurled section would be a better option. Much like this pic I found -
Wow the light looks stunning
Thanks for the heads up. Its an interesting looking knurl. Does it put much load on the lathe?
It does put a sideways load on the chuck, I probably should’ve used the tail stock or steady rest when I knurled the head part but you know…. I’m a lazy bugger :person_facepalming:
Given it’s a single wheel operation it couldn’t be used in a clamp style knurl holding tool. So there is no avoiding that sideways load.
Thanks EDSG. Stunning isn’t the word I would have used
I think EDSG was talking about that brass object.
Damn! Lol, that thing isn’t even a light :weary: :laughing:
Coming along nicely :+1:
Love the knurling.
I had a pretty crummy day today. Took the family dog to the vet to be euthanized. I tried to get some machining done in the afternoon but my head wasn’t in the game plus I was getting a number of interruptions from the family.
I ‘did’ get a bit done but the body is far from finished. I still need to shape and thread the tail as well as bore it out to the right size.
Sorry if you can’t see the video. I just got notified of copywrite on the music. Will re-do the video with different music tomorrow.
Sorry about your dog mate.
Very sorry to hear about your dog. That is a tearful event.
Really sorry to hear about your puppy.
Thanks guys.
I worked some more on the body today. Sorry no video to go with it. I found a number of flaws with the body and I’m not really happy with it but I don’t have any bar stock on hand to do it again. Nearly all the flaws are a result of the work I did yesterday. Another thing that came to mind is I don’t have a pocket clip to put on it. I’ll see if I can order one in time to finish before the due date.
Flaw #1 - seams in the knurling, plus it should’ve been knurled a little closer to the tail end. BTW I used the same knurling wheel, I just didn’t keep rolling until the lattice pattern showed and got dots instead.
Flaw #2 - I used a rounded cutting bit to get that nice rounded shape at each end of the knurling. At the tail end there is a ridge where I didn’t complete the cut properly.
Flaw #3 - I don’t know if it was in the chuck set up or the drill bit wandered but the boring didn’t turn out concentric at the tail end (tail end has a lot of problems doesn’t it).
It looks like the final length (when I get the tail done) will be longer than an AT40 but hopefully not quite as long as an E14
I think that’s not bad considering the fat driver and long’ish set up of a reflector.
Just the tail to make now. Then I can assemble it.
It’s good to see you pushing through with the build, despite the sad news.
I don’t think I’m up to making any more videos. Even I have to admit they’re not that interesting.
I have a tail now … If you look back at the very first pic of all the parts you’ll see the bar stock has knurling at each end. This is one of those ends. I nearly ran out of stock I seem to have produced a fair amount of waste.
Some of the threads look dirty because I used some metal polish to work the threads and smooth out the gritty feel. There’s also a few things to clean up like cutting the tail to exact size and a recess for the o-ring etc… Once it’s all cleaned up then I can start assembling and soldering. Nearly there
Very nice!
Looks terrific pp. Love the style.
Looking nice!!
You should have seen the amount of wood dust and chips I produced making all the small pieces for my lantern.
