Any updates on the tubes? or pricing yet?
Thank you for keeping track of all this for us and putting it together for the community
808HI +2
Wieselflinkpro +1
deus1ex +1
(post #196)
Please add another one for me.
BlueSwordM +1
Unloco +1
Hi!
I like two tubes and carriers so that I can use 8x 18650 in my Sofirn Q8.
19. Kasperrr +1
One note: Say how many sets you want, not how many tubes you want please.
For example, if you want to run 8x18650, say 1 set.
If you want to run 16x18650(DC Custom :D), say 2 sets.
Is the above correct?
I thought 1 set was for 4 x 18650. A set being one tube and 1 carrier.
One set of extension tubes is meant to run 8x18650.
Otherwise, why would you be buying it only for 4 cells? Haha.
I would like 2 sets.
For someone who wants to run 4 cells at 6v or 12v.
Plus it just makes more sense. Some people might want to run 12 cells. Why should they be forced to buy 4 tubes when they only want 3?
Wondering if a price has been established. It may turn out I need all 7 they showed in the vid….
Appearantly you can’t buy odd numbers of tubes. You have to buy 6 or 8.
I dare you! I double dare you! :-D
Interested in 1 set to run 8x18650 for BLF Q8.
Actually it’s 1+1, the first one is connected with the head, the second one is connected with the tail. If you wanna make it longer, it’s 1+2, 1+3….1+N
The first one never change, because you need it for longer extension.
I have read that you can not use the new sets together with the original battery tubes.
That means you need 2sets for 8 batteries.
And there will be 2 different tubes, for the BLF and for the Sofirn, which has different threads.
The original battery tube has to be set aside and not used anymore.
1 set = 2 battery tubes + 2 carriers
New vid on the Q8 extension tube:
https://www.youtube.com/watch?v=kmeRWGCQN6IAs you can see, there are 2 different tubes for the BLF Q8 and Sofirn Q8. No inter compatibility because of a slight thread change on the Sofirn Q8 for slightly better waterproofing.
The Q8 looks huge now though…
I love it
I must be missing something…near the end of the video, he takes off the BLF Q8 head sets it down, picks up and threads on the Sofirn Q8 head onto the same tube section that he just removed the BLF Q8 head from…. perhaps it does thread on but is not water tight so after this video was done they had to made a different set of threaded tubes for their Sofirn Q8 version? Is that correct?
I have both Q8 lights and you can put me down for +1 set but if truly different threads and have to specify which one I am not sure which I would pick right now, I know…the right answer is to get one set for each!!!
Must admit that I just found this thread, read from beginning and some good LOL posts in the last half helped me forge on to the end…so thanks to those that make this fun! You know who you are (BlueSwordM included)!
Interested in 1 set as well
1 set for me, thx
