I just got a couple for $6.96 shipped. The code says black, but it worked for an orange and a red one. I had to buy one at a time.
I also got the first batch when it came out. It was not reliable. It either skipped modes or stuck in Med mode refuse to go to High mode. I tried with primary, lithium, and rechargeable (eneloops and amazon basic). I gave up and just toss it in the drawer.
I carry a green one daily; it’s been dropped and banged around; still works fine.
I had trouble with the first black ones I bought. I would have to reemove the spring and re-insert it with the battery. Did not have ths problem with purple.
Thanks! just ordered one. i already have one and i think it is almost the perfect edc. o-ring broke off and i cant find the spare so now i get a light and can use the spare oring. hopefully it doesn’t come with NMM that my first one did.
What is NMM?
Next-Mode-Memory
I just got a couple — it’s the no-name driver, but has the 3 levels and hidden strobe.
One of them works fine; the other is intermittent, skips brightness levels, flickers up and down.
No wonder they were on sale.
Mine has sometimes disease too. Sometimes it works right sometimes it don’t. You never know what you are getting with it. It’s like playing the brightness lottery. You know it will light up, you’re just really not sure of the outcome. It has been relegated to a bathroom emergency light. I’d give it away if I wouldn’t feel so guilty about it.
got 3 last week. opened them up to do the pencil trick today. took 10 minutes for all 3 lights. Happy with the outcome. All lose memory after 3 seconds and return to firefly. before that with next mode memory as they came, they were basically unusable and a PITA. Now an instant favorite.
not sure if a 8$ light is acceptable if it has to be modded to work as it should… but now mine is good.
it is probably frustrating for a lot of non knowing people to get the brightness-lottery whenever they turn these on. I would never ever bought these lights if I had not read that I can hack them with a pencil to make them work like the original design.
I made a little hook out of paperclip, fished the spring out from the A01 battery tube, dabbed a little conductive lubricant on the wide end of it and pushed it back in place. That seems to have resolved the flickering problem. Probably if I’d looked I’d have found a sharp cut end on the spring that was making intermittent contact with the base of the battery tube.
It’s the cheap little corner-cutting parts that screw up the product.
No, I sure didn’t. It just really wasn’t that important to me. I bought it mostly because the wife liked the color. She swiped up a BLF348 instead. So it doesn’t really get used anyway.
did you “try the pencil mod”:Astrolux A01 next mode memory removal - Album on Imgur?
I greatly appreciate the pointer, very helpful.
That’s a good price - where did you order them from?
Are they Nichia 219b (or c?) and are they ‘always start on low’?
I regret not buying more from the first batch, I’d sure like to get my hands on a few more.
As others have stated, they are next mode. Too bad, great light and perfect for my use otherwise… but the “NMM” completely ruins it for me. I prefer M-L-H but can work with other similar interfaces as long as its no memory.
Just did the pencil fix on one of the two I just got. Perfect behavior now.
I’d like a word with the subcontractor who provided the wrong resistor to the builder (or the purchasing agent who found a great price on “almost close enough” parts).
Yay!
thats great to hear
And done the second one — harder as the wires were shorter, so I had to carefully push the pencil graphite into the tiny gap to hit the right spot. Nevertheless, it’s working properly.
I got 3 and 4 on order now. magic little good looking lights.
I just turn it on. Not the right beam?. Just click it till it is. Simple.
Have yet to have any intermittent power.
My Kids love them too.
The near perfect torch for walkabout work, Fit in pocket/purse.
and about the most well proportioned on the market.
Similar to the S-R1. They Just ’“feel” right.
I been using one since march 2018 in my keychain, many scratches from drops and keys, but i never got flickers. BTW i didn’t bother “modding” the capacitor because eventually it gets discharged(maybe minutes later or even hours) because the next time i use it starts in moon!
