The main purpose of the 16340 battery is flashlight use. Many popular pocketable flashlights are on the market that make use of in the USA widely available (non-rechargable) CR123 batteries, these flashlight are often used with (rechargable) 16340 batteries.
The 16340 is noticably smaller than 18350 batteries and flashlights for 16340 batteries are often used in the pocket of your pants, while 18350 flashlight are found by many people to be a bit too big for that.
The market share in general is not high (the 16340 is not used much in vaping), but for flashlights the 16340 is a very common battery.
As Djozz has stated, a number of compact flashlights use CR123 and are compatible with rechargeable 16340/16350s. Current draw for these applications is 1-3Amps most commonly. But the nature typical of BLF forum users are to prefer higher current capable cells. So continuous 5A would be a good limit for this size cell, in my opinion. I feel that a minimum requirement is at least STRONG performance at 3A.
This is very exciting news! I love the 14500 size because I have a ton of AA/14500 lights that can use this. I have a number of Sanyo 14500P but always wish the capacity can be higher. This will help a bit. What cell is under the wrap? Surprise it can beat the Sanyo in energy density.
Also, did you send the Sanyo NCR21700A to HKJ for testing? Really like to have that on his comparator. It seems to be the best 21700 for most flashlight use cases unless very high current is required.
This is not a protected cell, it has no electronics that prevent overcurrent or overcharge/-discharge. The PTC is a one-time fuse that will blow in case of a direct short, all li-ion cells from major brands have that.
