Aww, that’s a bummer. I was really looking forward to the power bank functionality. I understand if it can’t fit the equipment/schedule for this first version, and USB charging is still nice, but still. Bummer. Thanks for all the hard work though guys, I’m still interested in the one I’m on the list for.
Interested
Sorry for not being up to date on this, but does the light function well with just USB power without batteries inserted?
That hasn’t been tested yet.
I hope the answer is yes.
AT&T came up with a USB charger that would have “zero” vampire draw in 2010.
I think it had a solid-state relay before the rectifier/transformer and a capacitor after, and when the capacitor was full, it’d open the relay.
Plug USB device into charger, capacitor discharges, relay closes, device charges.
Unplug USB device, capacitor reaches charge threshold, relay opens until USB device is plugged in or the measurement circuit discharges the capacitor beyond the trigger threshold.
I may still have one of them laying around somewhere.
first prototype just soldered
as the team decided Power bank feature wont be realized but the pads are there
tested with NarsilM fully functional, so as planned after checking the layout like 3 times no errors on it
So excited to see actual prototype parts coming together. Thanks Lexel!
Nice job Lexel
v2.0 designed, sleep over it and see if any errors accured
updates:
- Power bank stuff removed
+ TP5100 2A charge chip installed
added on battery side a solder pad to switch between 0.75 and 1.5A
added + and chrg and full pads for Charge light indication
+ AMCs can now individually added or removed by pads on the battery side
3 AMCs per channel fixed up to 7 can be unlocked by bridging the solder pads with solder blob
That design i like!
Yep, that’s nice work.
May I request that 0.75A charging be the default, to minimise the chance of crashing a small solar panel?
I’m sorry to see the powerbank function go, but I’m still planning to buy at least one of these. I’ll decide what to do next once I’ve been able to play with the first one
for first version Powerbank got removed installing a simple charge board, then the preassembled charge boards were too big to reflow them onto the driver,
so it went on it as parts at least so we can control the quality of the used parts
default will be 0.75A
from the space also 0.5A, 1A and 1.5A would fit with 2 solder areas and 3 shunts, but I think 2 are well enough
No PB and 1.5A charger , great news! Is there any info about Micro or Type-C will be used?
I ordered one I need another one for a total of 2
Interested, please add.
If cost allows it we will try to go with the new type-c plug interface, as long as it don’t drive the cost per unit up to much.
This light is going to make someone a ton of money. I hope you folks working on it have watched out for your financial interests.
So we got the driver after long waiting hope the project become real soon.
At least Sofirn is using USB-C charging on the new SP36, so it is not new, they have the source for the parts.
