Miboxer C4-Plus Released on Amazon, BLF members enjoy 30%
Thank you. Order placed with coupon.
Do you have any plans to release a charger with micro USB for INPUT?
the charger works internally with a higher voltage like 12V as the C4-12
5V USB cant handle the power consumtion this one has
What I really would appreciate would be a proper USB type C input with 12V coding and cable
newer USB with high voltage supplies can support often 25-40W up to 15V which should work
Maybe you can find an adapter USB to 12V plus or make one
Yea I realize this charger is unable to but I already have high power USB hubs so I prefer chargers which I dont have to worry about power supply and cable. Just plug in to any port on my 5-6 slot USB hub.
USB C with power delivery spec or otherwise would be much better I agree but I think maybe one or none exist so far by any brand.
yes chargers have not USB C output, but the higher voltage and like 2.4A should be possible one side USB A and other type C to deliver enough power for this charger
even its not that powerful than the C4-12 it does not have the brick of external PSU which I do not like on the C4-12 and C2-6000 model
at least Dual input like Nitecore has for an external 12-15V PSU would be nice so it can be used in a car
The C4 Plus can also handle LiFePO4 cells as well as Li-Ion 4.35V cells.
Ordered, Amazon.de Thank you for the code Miboxer :+1:
Ordered from Germany but do you plan to sell it on Amazon UK?
I’m a noob when it comes to rechargeable batteries, and I’ve been looking at chargers for them, something for an Xmas present. I’ve been looking at chargers off and on for a year now, and finally settled on the Miboxer C4-12, until I seen this C4 plus.
I’ll proabbly mainly be charging 18650’s, I use a flashlight a lot at work, and they will mainly be for that to start. (I have to pick out a new flashlight too, but first a charger). I know I can get a cheaper charger that doesn’t have as many features as these two, but I am set on one of these, just in case I start getting more into it in the future.
My question for you with all the the experience, between the c4-12 and the c4 plus, which one would be better for a noob like me?
is this 2.5 amp, all 4 slots at the same time?
or up to 2.5amps for less than 4?
Also $36.95… thats the promo price for blf, or ………?
Ordered it this morning and it was $25 and change.
Add it to your Amazon cart. Click on cart and you will see a coupon. Click the coupon, then go to checkout and the coupon will automatically apply and lower the price.
As per the original post:
thanks for that
It’s mainly a speed difference. When charging 4 cells concurrently, the C4-12 will be able to charge them faster.
Other than that, the C4 Plus supports additional chemistries and additional (longer) cell sizes.
I’d like this level discount on the C4-12 !
Amazon shows that the C4-12 does support a couple 700 series batteries…
Can you list this on the Amazon Australia website or on Aliexpress with the special discount code? Australian customers cannot buy from other Amazon stores around the world.
This looks like a nice modern charger that can accept the longest protected 21700 batteries…
Seems like an improvement to the Miboxer C4-12, with just slightly lower charger current (C4-12 handles 4x3A, while C4-Plus handles 4x2.5A) but 2.5A and 3.0A charging time shouldn’t differ too much except maybe when charging those high capacity 5000-6000mAh 21700 or 26650 cells, right?
Max on the C4-Plus is 4x1.5A, or 2x2.5A.
One thing I noticed with mine is you can set the charge rate but it never charges at that rate. It’s always substantially lower then it drops rather quickly. Then the last 10mah takes forever. Shows a charge rate of a tenth or lower. Still seems like a good unit. I have plenty of batteries so I don’t have to wait on the ones charging. I know it’s designed so that it protects the batteries.
