Once it’s too thick to comfortably fit in a pants pocket, it may as well be as thick as the old D cell flashlights. I don’t see the point in anything between 18xxx and 26xxx either.
I have the JKK03; It has mode memory and can be switched off from any level with long pressure.
Other: the crown is compatible with that of the C8, at least with that in SS; I put the one in the SS, it screws well and remains only a “step” of about seven tenths of a millimeter between steel and aluminum. Then I put her back because I like it original
I have two of the little single cell Sofirn chargers. One came with my C8F and one came with my SP3. Both chargers are exactly the same and both will hold my Sofirn 21700 and my Shockli 21700 just fine.
The bottom of the charger Says- Li-Poly Charger, USB lithium battery charger for 26650, 18650, 16340, 14500, 10440 lithium battery.
I can insert the 21700 cell with about 2mm space to spare.
I’ll be darned. Lol. You’re right. Thanks for clarifying!! The charger it comes with does fit the Sofirn 4000 mah 21700 battery.
What that single cell charger does NOT fit is the Acebeam 5100 mah 21700 button top battery.
This could be a nice light for a powerful fully regulated and efficient boost driver with tiny sense voltage/resistor and massive inductor/caps powering 3S emitters. Yes, I am different. I like to have full blast on tap from start to end of battery discharge.
Thank you for stopping footstep. To celebrate Easter we would like to provide some codes for you guys on AMZ US & AMZ DE from 15th April to 22th April (USA Time) for our models.
BTW: Amazon CA and Amazon AU, also have a good deal, please check on amazon page directly we have cut the price already.
If you are new to Sofirn and Amazon.ca, be careful and look around. There are 3rd party resellers with ridiculous prices. Check to make sure it’s….Ships from and sold by Sofirn
I have a SP33. Nice light. UI is nice and simple. Plenty bright. Some weird tint shifts around the hot spot but not super noticeable in real life use. Easily seen white wall hunting though. Included cell tested out good. I haven’t done any run time test on it yet but I imagine it will run for quite sometime on the lower modes, which are still plenty bright. The Eco or moon mode, whatever they call it, is too bright to sneak around the bedroom at night but provides enough light to fill a room without blinding you when your eyes are dark adjusted already.
Worth the money I think. Sofirn always puts out a good product. They are my go to when I am buying lights for family and friends.
