Hmmmm, this is somewhat Disheartening.To bad he didn’t drop in this thread with info of some kind. .
The above link is to his last post & the info below is what pepinfaxera mentioned.
Sat, 06/30/2018 – 10:56….. #4112 / (last BLF post as of 10 November 2018)
fritz15
Offline Last seen: 5 days 17 hours ago / (info copied 10 November 2018)
.................................. "Slow is Smooth, Smooth is Fast" ...................................
How many flashlights do you want in total? … x … units? .
greetings, regards.
Well..this thread is a year and a half old. Excuse me for not remembering if i chimed in my interest at various points in time.
I honestly dont need the light im just trying to support a forum project. Like i said in my most recent post, ill take 2 if @$30
Its hard to gauge my interest since no details are final.
I think he was online just long enough to send a private message to the FW3A team. He apologized for not being around, said he’s doing okay but is very busy, and said he’ll make more time for this soon. Otherwise, the answers were “no” about changing the host design, and a plan to isolate the switch signal better by removing the outer contact ring on the spring side of the driver. That way, if the inner tube shifts a little, it shouldn’t touch ground.
Thanks for the info TK… . That is not so disheartening after all, since he did make contact with the people who count…… the ‘FW3A Team’.
I daresay Lumintop, Neal, DEL, TK etc. would just like to see it finalised and completed. As, I think, would we all.
I’d even re-join if I saw the prospect of that happening soon.
It still could be great, though I really do have my doubts about whether the tail e-switch will be reliable, which it would seem is still the difficulty at the moment. As well as the unique feature.
Fingers crossed that the next prototype corrects this.
It will always be a compromised torch, thermally. So little metal, so much raw power. If TK can keep it under control, that will be a triumph. Meanwhile other torches are available.
Tom Tom, you are the last person I would ask for an opinion on this project. Why, because you’ve already given your opinion time and time again even though no one asked you.
Are you trying to be the most disliked member of the forum? (besides those who have been banned)
Maybe try typing out your negative opinion and get out all of your frustrations like you’ve been doing, except instead of hitting the send button, simply delete it. Then you will feel better and at the same time nobody else will have to share in your misery. Cheers
Texas Ace Lumen Tube calibrated with Maukka lights
I do that sometimes. Sometimes I even take a screenshot before cancelling the post. It’s a good way to let off steam without making messes.
This thing finally got so old that I replaced it. It lasted for an estimated 200 million keystrokes, without ever giving me any problems, but I was wearing through the keycaps and wanted to try something new.
It sure looks nice, but you only know for sure after a million keystrokes give or take.
As for myself, I always was very fond of the classic IBM keyboards. It had a typical mechanical click, almost like pushing in the shutter of an analog foto camera (dare I say gun trigger?)
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
On a more positive note, It took Newport News Shipbuilding less time to build (and commission) the first ship in a class of entirely new aircraft carriers (Essex) than it has taken to put together this flashlight. Way to go Newport News Shipbuilding!
On a more positive note, It took Newport News Shipbuilding less time to build (and commission) the first ship in a class of entirely new aircraft carriers (Essex) than it has taken to put together this flashlight. Way to go Newport News Shipbuilding! ;)
I still have a couple old buckling-spring keyboards, but they’re pretty much never found in the 65% form factor I like. So I have newer keyboards with MX-style switches.
According to my logs, this new one already has about 5 million keypresses on it.
I’m tempted to look for one with Kaihua Copper switches though, instead of the Hako True switches I’m using now. It’s a lighter touch, more tactile, and less spongey toward the bottom. Or maybe I’ll just finally get a key switch tester board to try a wider range, and find a keyboard with hot-swappable switches. I happen to know a guy who is making one, and it runs open-source firmware, and I’ve already added stuff to that firmware…
In 1941.
The current construction schedule isn’t quite as tight.
Noticias:
fritz15 , visited this forum 5 days ago.
fritz15
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
fritz15
Texas Lumens Flashlights / M4D M4X Deals : sign up - save $$$$
Rudeness Level _ mΩ _ {width:70%} _ LightWiki _ LED Tint Chart
Xlamp size chart _ BatteryU _ Flashaholic? Need Professional Help??? TheOriginal _ TAB _ LightSearch _ BatterySearch _ 14500's _ DiCal
Thanks TK for the information about the situation!
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
stasis; normal
I’m in for one
Edited to remove negativity.
Click this to go to signature links.
The letters on my keyboard are no longer visible
- LEDs & Other Stuff - - UI CheatSheets - - CRX Mods & Builds - - Stuff for Sale -
- The Old Lumens Flashlight Modders & Builders Challenge is Now Open - Link -
So now I’m using one of these:
Very nice
give or take.
I still do have one mechanical keyboard from 1998.
Got passed down from my father to me.
Multigenerational keyboard still working
@JasonWW
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
Good thing the FW3A is just a flashlight. Right?
Flashlight are way more complicated than Ships. But good job anyway.
There’s more than one rabbit hole to fall into.
One for me. Thank you
Hey! Leave my rabbit hole alone! Barely room for me in there and I NEED my rabbit hole!
(Thelonious Monk makes it habitable.)
Lance_Hardrod would like 2 of these lights.
Great stage name.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
Please drop me from the list #963 Thank you! Good luck to all!
In 1941.
That’s a nice mecha.
What brand & model is that?
https://www.instagram.com/lumenzilla/
