Do you think recharging when the light goes dim would eliminate that concern?
note these lights start at about 5 lumens,
and the vampire mode is well below 1 lumen,
so it should be obvious when the light needs a fresh battery, no?
Go to “My Orders” You will see the order there with status as “Awaiting Payment.” Refresh every so often until Sofirn changes the amount from 7.02 to 6.50, then click “Pay Now” to complete your order. You will be charged 0.80 to use PayPal on Ali though, which is normal.
Thanks dijozz for confirming that a 5 x 3 mm magnet holds the light well enough :THUMBS-UP: .
Now the wait for the red and blue batches begin, hopefully they will be ready at the same time, so you don't have to order multiple times if you want both.
I almost want buy one of these to see what it’s all about. Is it the CRI that makes this light so popular? Seems durable according to the video. Just seems as though the output is fairly low which is what is keeping me from pulling the trigger. I have a Nitecore Tip and got my wife the Astrolux K1.
I’m fairly certain going below that won’t kill them very quickly, but I’m sure it lessons their cycle life. I wouldn’t be afraid to use NiMH in mine, but I probably would go ahead and charge once I start to notice any dimming.
The CRI and the even, floody beam are the main differences between this new light and the Fenix E01, a light long appreciated for it’s durability, efficiency, and ability to get as much energy as possible from its battery.
In many situations, high outputs are not needed. Those are the times when the C01 will be at its best, but it won’t substitute for the Tip or the K1 for the times when you need a lot of light.
> Not much lights can fire up with almost dead batteries. This one can.
Aye, there’s the rub. Check the voltage on NiMH when you notice a drop in brightness and let us know how low it can go.
I’ve grown wary of ever using alkalines because I realized they can keep a LED flashlight adequately bright while they’ve already leaked badly —- I used to rely on the dimming of incandescents to clue me in to change alkaline batteries before they could leak.
At the time of writing the price is US $6.93 - even without the BLF discount that seems like a good deal to me. Fr me the biggest reason to apply for the discount is to let Sofirn know that BLF members are following through and ordering.
