Just look at the UF10 batt+ contact board above, and what I stated couple times earlier of measuring 51 ohms between batt+ brass button and the head housing, so there's current running through there. The UF10 has that hidden "thing" under the white hardened goop -- hhmm.
John from FB said: Mine turns blue and it gets quite hot. I've never seen one turn that color before and thought maybe mine was the only one like that. I'm going to see if I can get my money back. This is my first and last Folomov.
I emitter swapped my Folomov 18650s today. :sunglasses:
This fixed the issue I was having with the emitter blue-shifting and getting dimmer with some fully-charged cells. Turns out the 219D just can’t take high current.
No pictures, but here’s how to emitter swap the 18650s:
The head looks like it’s in one piece, but it really isn’t. The bezel is the smooth portion ahead of the fins on the head. It’s just screwed onto the head. I applied 3M indoor stairway grip tape in a ring around the head and another around the fins and unscrewed. The bezel came off easily. There was no glue, but there is an o-ring.
With the bezel and lens removed, lift or tip out the smooth reflector to reveal the star.
The star is copper and is screwed onto the full shelf on the head with 2 screws. There is one wire connecting ground to the star. On the back of the star is a soldered post that directly contacts the top of the battery. The star also has 2 resistors on it. There is no other board at the head of the light. The driver is in the tail.
Desolder the negative wire from the star, then unscrew and lift out the star. Some thermal paste was used under the star, but more would be better.
The hardest part was heating up the star enough to remove the emitter without the post on the back getting out of position. I used a wooden clothesclip held sideways in a vise to grip the post on the bottom of the star, then used hot air reflow to remove and replace the emitter. I replaced it with a XPL V6 3D that I had laying around. I might end up replacing this later with an XPL HI for more throw.
I also added a copper disk onto the bottom of the post at the bottom of the star to allow flat-top cells to be used.
Got mine yesterday and decided to try a burn-in at the medium setting, tail standing for a half hour.
Used a Sony 2600 laptop pull charged around 4.09.
Light got mildly warm but no problems.
Have not tortured the light at full voltage on turbo for more than a few seconds and have decided not too.
I Love the tint and have plenty of other pocket rockets that can be used for “shock and awe” but this one will just be used in an EDC setting and will leave alone.
That may very well be Un-BLF of me but do not want to give up on the good overall function of the flashlight at this point.
Will just use with a battery that is not full up and/or high amp.
If Folomov comes up with a solution, great, but for now it’s good to go.
It does not appear to have low PWM and has the perfect (for me) moonlight and also like the mode spacing.
Really wish it had a BLF A6 style driver with reverse mode switching but it has memory so can chose setting I like and leave it and still have access to Moonlight.
Also love the Soft Ramp Beacon, very nice touch.
Cool! Worked on a HT35 so didn't have time to work on the head. Back in post #45 I thought the bezel was removable. Does it do well on turbo/max now? Was wondering roughly how much amps. Probably the 219D is very low Vf so the amps can get way higher than with a XPL, but depends on the driver design.
Yes, replacing the 219D with an XPL fixed all problems with the light. It now functions perfectly at max power now on all 18650 cells that I’ve tried, including fully-charged VTC5A.
Do you think that the whole procedure can be accomplished just with a soldering iron and a candle?
I do most of my emitter swaps just by hitting the bottom of the star with a candle as no hot-air station is available to me.
2nd piece came in and bezel was easy to unscrew - no glue:
Well, the 51 ohm resistor is there - exactly what I measured, so that's how the tail driver gets it's batt+ power. Looks easy to swap the LED, maybe a 351D 4000K 90 CRI.
I swapped the LED on mine. First to an XPL and then again to an XPL HI.
The hardest part is the cylinder on the bottom of the star is soldered directly on. Heating the star up enough to reflow the LED also causes that cylinder to fall off.
This problem is easily solved, but you might need to adjust your standard reflow technique a bit.
Thanks! I swapped in a 219C 4000K hi CRI LED - now does about 600 lumens at turn on and gets warm pretty quick. On my reflow, the brass cylinder thing didn't fall off because I used a hot air gun from above. Went pretty quick. The MCPCB is pretty strange. The batt+/LED+ flows through the MCPCB itself, while the LED- comes through the light's body, so, the MCPCB must be isolated electrically. The anodizing on the shelf isolates it, so don't attempt to sand it down.
I'm amazed at the good reviews and claims of the 900 lumens. What happened to honest, technical reviews where #'s are measured, not quoted from manufacturer specs?
Boy, everyone wants in on the action to make $$$. Shame the most popular reviewers are the least technical - they don't even know what they are saying is fabrication. This light has a serious design flaw, way overstated specs, and it's an "Amazon's Choice".
So if the shelf ano is damaged, the led is bypassed (but not a direct battery short because the battery-minus goes via the driver to the body).
Weird design! I will have some thought about what to do with this light once it comes in. Is the reflector any good? I could swap in one of these new Osram thrower leds.
I might have missed a post concerning the current on turbo. Does anyone know what the actual max current for the flashlight is? I think the specs for absolute max current for the 219D led is 1.8 amps. Anyone know ?
What the mx current for the 219D is, is not measured yet by anyone. Usually (if you ignore the 50,000 hours lifetime) it is more than what the datasheet says.
