I”m not sure what you are talking about. :question: I thought we were trying to determine if those Liitokala 26650’s were any good. Not comparing them to 18650’s.
The blue 5100mAh cells are well under 5000mAh at 500mA.
The blue 5100mAh cells are well under 5000mAh at 1500mA.
My real LiitoKala Black and Gold –50A cells test over 5000mAh on the same primative toy engineering chargers. On top of that, the AC impedance of the blue cells is higher than the black and gold.
I would be very surprised if using a high-precision constant current load, 4-terminal battery holder and $2000 bench DMM finds the Blue 5100mAH “LiitoKala” cells are 5100mAH as advertised or even as good as the 5000mAh black and golds.
True, you have not seen the most important thing. And about this I have already said a little higher. However, if you do not understand, then I can repeat that you can’t fully check advertising promises for these blue Lii-5100 (or 5000), having a regular device with a discharge current of only 500mA, as advertising promises 20А. Who needs your 500mA, if people buy 26650 for large currents (not at all for 500mA) :question:
They show to sell the Liitokala 5000mah, not 5100mah. I can’t find any pictures. I would guess they use the proven older cyan or black cells that so many of us use for high powered lights.
If anyone knows what battery they use for sure, please post it.
Understand, instead of specific and visual graphs, everything there is just words and assumptions, which may or may not be a fact.
The fact is that today there is no confidence in anything. For example, no one knows for sure if these are the current black and white 26650 banks from Shockli, what were the former red-black Shockli-5500, previously tested by the master HKJ and the results of which we all have long been familiar with? Then how can you confidently talk about something about the new models KeepPower-6000, which HKJ has not yet really tested under the same conditions as all the others?
They look to be selling genuine first brand cells. There are also some strange affairs in the “26650 Battery - OTHER” section, namely what seems to be two chinese OEM cell types (cian blue and blue wraps) and non-genuine Panasonic 26650s
It’s hard to have confidence in anything. If You have confidence in the Keeppower 6000mah is what matters. Others have said they measure the same capacity and perform exactly the same as the Shockli 5500mah. If your confidence about them is low, buy the Shockli version.
volchyonok, those oversized images mess up with the forum layout, you can reduce their size and fit them to screen by adding a {width=100%} prefix after the first exclamation mark in the insert image simple post editor code. For example:
I trust them. So if this is “the good one” I might check it out. But back on topic…
I have the black and gold lito that came with my D4S. It came from int-outdoor. It’s been killler! Charged and discharged it about 16 times already. No percieved loss of performance. I beat it down to just about 3v and charge it back to 4.2 — I think my SkyRC measured IR in the 30s.
