Hello.
I want to buy a flashlight.
A friend has an Olight thrower that sees a 1km (xpl-hi 1100lm). I have a thorfrie s70s that sees 600m, sees much stronger but I would like to see it more distant than his. It has a very concentrated beam of light. The stronger light is on me, but she does not see that far.
What do you recommend me to choose? Both are $ 175.
I am very indecisive. I want to have a strong point of light but have many lumens. On youtube I saw that MF04S has a light point but it’s wider, I do not know how concentrated it is to the one with xhp35.
The one with the XHP35HI is extremely concentrated, and can throw extremely far, 2km+ in perfect conditions.
The XHP70.2 version still throws extremely far, but less than the XHP35HI version.
However, due to the sheer power of the light, it still does throw far, but in a wider range, making it more impressive in general.
They are still both superior
to the Olight thrower.
I would go with the NW XHP35HI version however just because it throws farther still, has a better beam, and can still be used for very good throw at low levels.
Do you prefer a laser like beam or a bigger hotspot, do you want to see what is around the target you are pointing at or just the target?
If you prefer a laser like beam that throws really far go with XHP 35 if you like a bigger hotspot that still goes far (not as far as XHP35) but you can also see everything in the path of the beam towards the target, then get XHP 70
What is going to be the intended use for the light?
Re-reading your post, seems to me that you want a FAR thrower that throws farther than your friend’s , then I would suggest you go with the XHP35
They want to see at a distance and wide. I do not really know how the differences will be. My friend’s SR52-UT Olight has a very focused point, he sees much stronger than my Thorphire. I think Olight has 1100lm and it’s ok, and MF04 is 2700lm, so he’ll see even stronger and much bigger distance.
Seeing that you already have a XHP-70 led flashlight in that Thorfire, then get a XHP-35 so get the MF04 in neutral white to reach farther, or if you want to see the laser like beam in the air then the cool white would be best, what tint beam does your friend has? do you like the way his beam looks?
Sounds like you got yourself in lot a longest d/(& contest.
If you buy the MF04S now and they then buy the MF04 to beat you, how would you feel then?
With either choice, they can always say you bought a torch the size of a toaster oven just to beat them, how would you feel then?
If you’re indecisive it’s cuz you know you don’t really want or need either. Put the same exact money into a Reylight TI LAN Winter Frost with 16 trits and you can take that mofo anywhere and it’ll make your buddy jealous too. Win win.
I have both the MF04 and the MF04s, MF04 all of the way. The hotspot just isn’t large enough at a distance to make a huge difference (for me) and I appreciate the more concentrated beam. On top of that it uses less power so you have longer run time, and it takes longer to heat up so you can comfortably run it on turbo even longer.
Really though it depends on the distances you plan on using it. At close distances <100 feet, the hotspot size isn’t big enough to make a difference. At medium distances <1000 feet, you might appreciate the MF04S more, at long distances >1000 feet, the increased beam intensity means the target will end up brighter with the MF04 anyways so while the MF04S will have a bigger hotspot, it won’t be illuminated as brightly.
If throw is at biggest priority, I think MF04 is better, because it uses significantly less power for the same throw distance.
XHP70.2 is not the best, because for a good throw, it uses too much power, so the flashlight host gets hot in a relatively short time, then the driver will step back, and thus, throw will be reduced as well with the output.
For people, who want more light output, but still great throw, XHP50.2 could be considered as well.
Regarding color temperature, a neutral white around 4000K will throw much better over longer distances, as violet/blue/cyan/green light gets scattered significantly more in the air, than yellow/orange/red (based on a few physics facts). So the NW flashlight will actually illuminate the target better, instead of making a ‘laser beam’.
I think, for long distance throwers, high CRI 3500K or 3000K CCT emitters could be even better (for me, the sweet spot could be at 3500K).
EDIT: as DB Custom says, I told falsely, that NW/WW emitters will throw better. NW/WW emitters have usually slightly lower performance bin. I still think/experience, that perceived contrast can be noticeably better, when air conditions are suboptimal.
I will tell you I have both. I like both but the MS04S was awesome. Given the distance the human eye can actually make out an object is less than what these lights are capable of. The MF04S would be the one I would pick (Personal preference/opinion). A neutral white will not wash out the objects as much either. You will not be disappointed with whichever you choose.
