+2
Making your own multi mode rotary switch from scratch .!!! OMG ā¦
Youāre a true torch building professor
We both agree on something.
Very nice job :+1:
Interlocking copper core sections.
Previously made to fit inner core copper tubes.
I cut a 33mm section off the outer core tube and filed ends flat, then cut a 16mm section.
Cut a 25mm section off the inner core tube and marked out slot positions on the ends of both sections.
Using the file then flat stones I smoothed off the end sections square...
To make two neatly interlocking inner core tube sections.
The idea being, with the rotary tail switch, the sections will not move when holding the light/ rotating the switch. Most of the inner & outer copper core pieces, exploded view.
Showing interlocking sections and head rubber o-ring placement. Inner body cores roughly put together. The tail end still requires to be shortened to fit the cell & rotary switch.
:+1:
And everything fits so nicely! I wish I had the skills to do that too.
:+1:
:exclamation:
Magnetic copper charging unit.
Using an old integrated flashlight USB charging board, I removed the momentary side switch, soldered on a 6mm x 2mm magnet to the centre positive contact with a positive pass through wire soldered directly to the side and a negative wire to the negative via on the board then soldered on a 6mm x 2mm magnet to the end of the positive wire.
I had to make a copper enclosure for the unit by cutting a piece of 22mm copper tube and bending it to a smaller diameter when closed together to fit into the copper body core.
Using solder paste and a dual jet flame lighter I applied the solder paste to the open ends, held the joint shut with grips and fused.
To make the enclosure stronger I cut a piece of 0.3mm copper sheet to the correct length to fit inside the thicker outer shell, applied more solder paste, held with the grips again to prevent the original joint re-opening and soldered all together.
The joint of the inner piece is opposite the joint in the outer piece for structural strength.
Some filing later...
Drilled out a 7mm x 2mm slot in the enclosure for the USB port and filed the hole into shape with a small diamond file.
The piece looks happy enough about this :-)
Drilled a 1mm diameter hole for the charging indicator light near the charger board LED and filled with UV setting glue, filed out a slot in the enclosure opposite to the port for a thin copper strip to slide into.
Filed around 0.5mm off the edge of the charging board to fit the enclosure diameter, pressed the charger board into place and soldered to ground with the soldering iron. Also soldered another 4mm brass tube with double springs inside to the negative wire.
Potted components side with a layer of UV setting glue, some kapton tape covering the USB socket and JB welded the spring enclosure in place in line with the filed out slot.
The clear UV glue will carry the charging status indicator light to the external 1mm hole I drilled.
Potted the remaining spaces and positive contact magnet in place with JB weld & tidied up with fine wire wool.
Tip: Use BluTack or similar to remove any metal debris stuck to magnets.
The reason for the slot I filed into the case & sprung brass enclosure is to accommodate a magnetic copper negative connector, this can slide in position to fit different cell lengths although won't be used in the actual light, but it's there anyway.
The charging unit has a 1A maximum charge current.
Charge test: Red :THUMBS-UP:
Showing how the unit fits into the inner core body.
Added a 0.2mm thick copper skirt for a slight design change.
This is because the charging unit will sit further into the head of the light now with a chosen shallower reflector and give a snug fit in the inner copper tube.
I filed the outside of the charger unit enclosure to reduce the diameter by around 0.4mm, cut a section of copper sheet to size, filed edges smooth with the stones, applied solder paste, held in place with grips and fused together with the jet flame lighter, a slightly nervous moment doing this but it turned out fine :-)
Had lots written but deleted it. lām just awestruck with your talent.
And your Patienceāā Awesome stuff here
CRX, youāre on a whole ānother level!
Iāve heard that soldering magnets affects their strength. Have you noticed that? Do you have a way to mitigate that effect?
I recommend Bi57Sn43 solder for magnets, makes things much easier. But watch out for fakes.
An absolute wonder!!!
Thanks very much for the comments, much appreciated
Yeah heat will destroy the magnetism, even a seconds contact with the iron will affect it so you have to be fast, Neo fastā¦ :laughing:
Not the first time Iāve had to replace a soldered Neodymium magnet because I applied too much heat, plus the damn things will jump onto & stick to your iron tip until they kill themselves and fall off :person_facepalming:
I solder as fast as I can, wetting the surrounding area first and dragging the solder to the magnet. It helps to have the magnet stuck to something else too, to wick away heat, like a piece of thin copper sheet then more magnets on top.
I think type N lose part of their magnetisation permanently at a temperature of around 60-80Ā°C, though there are different types and a lower melting point solder would help too as mentioned but I only use silver solder with added cadmium
Sometimes, I wonder myself
Thanks for the explanation
Neo wasnāt just fast. He could see the source code of our world and change it to his will. I think this build easily proves that CRX really is the Chosen One. Whereās Agent Smith? :cowboy_hat_face:
