@DB Custom and BPlayd0h, there is the 5700k Luxeon MZ 90CRI for you, and the 5000k LH351D 90CRI.
However, don’t you both forget that there is a large difference in how 3500k and below emitters are represented in pictures.
Emitters with low R9 values and high CRI values will tend to look on the orange side of things at 3500k and below CCTs. See the XM-L2 3000k 80CRI above. That is due to the green wavelengths of the light emitted mixing it with the red, giving it a bad orange look. Doesn’t look bad, but doesn’t look good either, even to my warm tinted eyes.
Emitters with high R9 values and high CRI will tend to look towards red at 3500k and below. See E21As and LH351B 3000k 90CRI. They look gorgeous, even on a white wall. It looks more realistic since red tones are less washed out, making it look more reddish in tones, giving it an incandescent tone.
Kinda, yeah, it’s got 72 dies and dwarfs the 70.2. lol It can do a little over 16A direct drive for some 4300 lumens. I’ve had them in all sorts of lights, even a chopped miniMag with 2 14250 cells. (that’s the 6V variant, I also have some 9V ones)
I’ve tried a dozen different 3000k emitters. The Oslong Square 96CRI, E21A, and SST-20 is the best. I never tried the LH351B 3000k 90CRI though and never seen any test report on that but fear it might be above the BBL yellow/green like the other Samsungs. You can get a SST-20 3000k 90CRI triple on 20mm mcpcb from KD and just swap it in the TO46R. I modded three TO46R that way. Very easy to do and direct fit. No physical modifications necessary. The SST-20 3000k 90CRI looks beautiful in this host. Does not look yellow at all.
Older eyes are generally more frazzled, even if they started off perfect. Particularly if the owners have spent a lot of time outdoors without protection from UV and high intensity. They wear out. Look after them.
10% of male eyes are defective to begin with. 0.5% of female eyes.
The blue cones are most easily damaged, hence I suspect a preference among some older people for colder tints, to try to make up for what they have lost.
My other Wuben To46R is getting the LH351B 4000K 90+ CRI soon
Texas-Ace is sending me one of his nifty Lumen Tubes and I want to measure the stock light before I mod it.
This was a super easy mod. The triple emitter, 20mm boards from mountain Electronics drop right in.
Remove tailcap and battery.
Unscrew the bezel. I pressed the bezel into a piece of foam and turned the body.
Pop the open tail-end of the light a couple of times with the palm of your hand to generate a slight increase in air pressure inside the light and the lens will drop out.
I used a fine tip pair of tweezers to remove the o ring and the optic fell right out.
Un-solder the red and black leads from the original triple emitter board, straighten the wires a bit so they don’t catch, and the emitter board drops right out.
Thank you! Looking forward to seeing more! I have heard, as SKV89 stated, that the Samsung LH351 has a green corona, though I’m not sure which exact LED it was so hopefully you have a better outcome.
Also thanks SKV89 for the tips on emitters. I’m going to order a few and get my Weller out this Winter!
I have recently used a lot of the Samsung LH351D 80 CRI 5000K emitter, I don’t see this green that has been much ballyhooed about when used in reflectored lights or certain optics, other optics do indeed shift the tint. I don’t know if that’s just the batch I got or what, but mine have been fairly pleasantly warm. This is a U6 power bin. The W6 power bin in 70 CRI 5000K is actually almost white and quite a bit stronger. I prefer this 70 CRI W6 to the 80 CRI U6, both in 5000K tint.
That’s great There are a couple of catches in there too
I think if you start off with decent eyes that they mostly carry on working, just fade a bit at the cooler end as we get older.
But other things can also start to go wrong.
It used to be that no-one used headlights in town, we had “sidelights” for that, only switched on at “lighting up time”, still do actually, still legal, but no-one uses them. A pity, because bicycle lights etc. now have to compete with car main-beams and glaring “daytime position lighting”, and as a motorcyclist I have had to add a couple more lights just to keep up with the lighting war and try to stand out, as well as a helmet cam, just in case. Whereas it used to be easy, just keep your headlamp on dipped beam.
It used to be in France that white headlights were illegal, only yellow tinted bulbs were permitted, and it used to be a ritual for my father to change them over, and mask out the LHD dipped beam with tape, just before we crossed the channel in our VW camper, back in the ’70s.
I know several elderly people who are almost night-blind, but can still cope well enough around town, wearing yellow-tinted driving glasses. They were much happier when we still had high pressure sodium streetlights (orange), but the modern cold white LED ones don’t suit them at-all (as well as being much dimmer).
This test is more subtle, but I can also pass it easily:
That is very insightful. I’m 70 years old and spent 3/4 of my life working outdoors and the other quarter working indoors under fluorescent lighting. Not to mention I grew up by the beach in Southern Calif. and spent most of my free time in the sun without eye protection.
I’m very susceptible to warm tints that so many here love as they are very distracting to me as well as green tints. CW without any blue or green is my preference by far and is the easiest and most pleasurable tint for me.
I rode a 750cc (Honda VF750S, V45 Sabre) for years back in the 80’s to 90’s, put 50,000 miles on it. Mounted an auxillary light under the main headlamp even then. Wanted to be seen, not hit!
Honda CB750 KZ when I was 20 (unconditional job offer from BAe before I graduated convinced the bank manager to give me the loan.)
Then more big Hondas, moved on to BMW. K100 RT, K1, R1100GS (still have the last two, the K1 being rather a classic. As well as a little Kawasaki KLX250 to put on a rack on the back of the camper.
Also swap these around with a trusted brother, modern BMW750 GS, classic R100GS PD in as-new condition, replacing the one that we wore out over a decade of long European tours with our GFs on the back. Honda XR400 (Australian import stripped down and tuned, doesn’t even have a battery), Suzuki GSXR750. Honda Firestorm 750 twin, several big Kawasakis, etc. etc.
Can’t really have anything 6000K or north without some blue, that’s how blackbody radiation works after all. I would imagine worse rendering of the rest of the visible spectrum is what makes some emitters look so much MORE blue than others however.
Between a slightly green hue and tons of tint shift I will take the green every time. To me its the wild shift in colors as you move the beam/your focus that is really disorienting and makes colors hard to distinguish. XP-G3 HCRI is a great example of this, I would take MANY other emitters over that.
