I still have a couple old buckling-spring keyboards, but they’re pretty much never found in the 65% form factor I like. So I have newer keyboards with MX-style switches.
According to my logs, this new one already has about 5 million keypresses on it.
I’m tempted to look for one with Kaihua Copper switches though, instead of the Hako True switches I’m using now. It’s a lighter touch, more tactile, and less spongey toward the bottom. Or maybe I’ll just finally get a key switch tester board to try a wider range, and find a keyboard with hot-swappable switches. I happen to know a guy who is making one, and it runs open-source firmware, and I’ve already added stuff to that firmware…
There’s more than one rabbit hole to fall into. :slight_smile:
One for me. Thank you
Hey! Leave my rabbit hole alone! Barely room for me in there and I NEED my rabbit hole! :wink:
(Thelonious Monk makes it habitable.)
Lance_Hardrod would like 2 of these lights.
Great stage name.
Please drop me from the list #963 Thank you! Good luck to all!
In 1941.
The current construction schedule isn’t quite as tight.
That’s a nice mecha.
What brand & model is that?
“you have exceeded your max allowed credit”
please reapply
Once again, I’m confused by your posts.
I have the impression his wallet thinner detector broke loose while seeing that keyboard.
These types of keyboards do sell for a pretty penny.
It’s called a WhiteFox. It’s one of very few models I’ve found with the HHK+arrows layout (HHK = Happy Hacking Keyboard). I have the keys on mine rearranged a bit compared to the picture, but it’s still reasonably close.
If I get another any time soon, it’ll be similar but with a split space bar, RGB lighting per key, hot-swappable switches, and cleaner firmware. I made a physics simulation of a swimming pool which responds to keypresses and splashes colors around as if each key stroke is someone dropping a bowling ball into the pool. It’s totally unnecessary, but it also makes typing really satisfying. Did I mention I like shiny things?
WhiteFox and Tada68 (what I’m using with Aliaz Silent 70g) and definitely the most useful in that size category. I don’t need a numpad or whatever that other cluster w/home, pg up/down is called but my arrow keys aren’t going anywhere.
Having Esc on the same row as my numbers is also literally a lifechanger. I don’t code but I see zero reason for tilde to take that spot.
I use tilde a lot, but I like it on the upper right corner instead of upper left. I use Escape a lot too. And with Backspace moved down one row, there’s a nice empty space to fill.
Hi, can you please put me down for 1 too? Thanks
I just cut copy and send them in a pm to Boaz. Wonder how many people know that they can send PM’s to themselves?
I don’t read them ... now I’m wondering if I can block pm’s from that lunatic ?
Try Googling “Stasis field”
I don’t have a problem with definitions.
Maybe it’s a reference from a game or movie that I don’t get? I don’t know, but it doesn’t seem related in any way to this thread.
Fuel reserves; depleted.
Please deposit $1. Thank you.
Interested (1)
You are not alone Jason…. :wink:
