The few times that I measured it (old type cool 70 CRI Cree XP-E2, XP-G2 and XM-L2), the light loss was close to 10% for a clean dedome. But it may vary, I only measured it a few times.
I can not find back my numbers on the XP-G2 and XM-L2 (I never managed a good dedome of the XP-L) but here is what I found for the XP-E2, it was even a bit less than 10% for these two leds:
The Samsungs from the Q8 were from AEDe’s first sale, but the sliced ones from the SP36 were recently bought from led4power. I should have mentioned that, but I did not see an obvious difference in tint between those two sources (I know because when I bought the l4p ones I hoped that he had sourced a batch with a tint closer to the BBL, but it was clearly not so but instead very similar)
I did not test the slicing of that exact led (I could not find my stash) but I did try it on the 5000K 90CRI LH351C, the SPHWHTL3D50GE4RTMF to be exact, that maukka did extensive testing on (link). The effect of slicing this led should be similar to slicing the 5000K 90CRI LH351D though.
I now did my homework and did do the tint measurements before the slicing too.
I modded a Utorch S2+ clone with the SPHWHTL3D50GE4RTMF, and with a 2.8 A biscotti driver. All tint measurement were done in the hotspot (which is the most relevant part of the beam that you want data of).
First with intact led at 2.75A
Then I sliced the led, not the cleanest slice but I’m beginning to suspect that how close you are to the die has more impact on the led behaviour than how even your surface is.
Now with sliced led at 2.75A
Same sliced led at 20mA (not from biscotti driver but by connecting the flashlight head to a led tester, so not PWM-ed)
Now apart from the colour data, that show a very similar effect as the slicing of the 4000K version (lower colour temperature, preservation of CRI, closer to the BBL), the beam looks like a very good neutral tint: no green, not too yellow, not too rosy, I like to call good coloured neutral tints “brownish”. Here is a beam shot for an impression, all lights are at fairly low level, the sliced LH351C beam is in between a (led=intact) LH351D 4000K 90 CRI beam (Q8), and a 219B 4500K R9080 (ROT66, beam from TIR optic).
(the Q8 is a bit too green, the ROT66 is a bit too red, the picture shows less tint difference than reality)
I also measured the light loss from the slicing of the led and I now got –19%, so that is also similar to slicing the other Samsung led.
One thing not mentioned before: slicing causes better tint and less light, but of course it also decreases the spot size of your beam and increases throw (did not measure by how much, my educated guess is 35–40). This can be relevant to what flashlight you are building.
If you feel like it, you could also do some staged slicing measurements in some other emitter. I mean, to see how does it compares a not so close slicing versus a close one with regards to output, hotspot size, temperature and CRI. Should be a gradual regression/progression in those parameters, I believe.
Yes if you use a new one. Some people use very fine sandpaper to polish it but i’m not sure anyone has proven that to be of any benefit and it can even be harmful if bond wires are involved.
Try one partial slice as a test, it’s generally very smooth. Then, go for a deeper second cut.
Edit: this is probably obvious but you want to make sure it’s soldered to an MCPCB so you have something to securely hold it. You can use a flat washer over the top as a guide if you can get it to the right height or just freehand it.
I am waiting for the LH351D 5000K 90CRI to arrive at you
I would be very happy, if I could see spectral/CRI measurement before I will buy them. If results are promising, I might exceed my initial interest numbers.
I can remember, that you have (or you did have) LH351B 2200K of two different performance bins. What is your current stock of them?
