I didn’t know Wasabi would do that. How bad was it?
Last week, I chopped up a Chocolate Ghost Pepper and put the whole thing in my bowl of Chili. It added a nice heat. :smiling_imp:
I washed off my hands after chopping up the pepper, scrubbing and using dish detergent to try to dissolve it off my skin. Later, I was eating some thing with my hands, and burned my mouth again from the heat that was still there.
You could do it too. Surprisingly, pepper heat is something you could easily build up a tolerance for. Start with something that only has a little heat, like Cholula. Add some to your food, and assuming you like the flavor of it, you’ll find yourself adding more of it each time after a while. Then, move up to something hotter until you get used to that, then hotter again, and so on. I couldn’t have eaten a whole Ghost Pepper, even with a whole plate of food, just a year ago. There’s also some variation in heat depending on the growing environment. I don’t think these peppers I have are nearly as hot as Ghost Peppers can get. But, they’re close enough for me.
Trivia fact: A lot of people don’t know that the “hotness” of peppers isn’t really hotness, or even a chemical “burn”. It is simply a hack of nature. It’s basically just telling your hot/burn/pain nerves to activate as if there really was some heat applied. However, it is possible to be allergic, and have some very bad reactions. But that is a different matter.
It’s amazing how many people think Cholula is hot. And it’s fun to watch their faces when I put some into a shot glass and calmly drink it.
It’s the pepper equivalent of impressing muggles with a 150 lm flashlight. Like a D4 at its default level. “Ooh, that’s bright!” “If you like that, you should see it on a high mode…”
Damn, my FL craze lasted for about a year and I managed to get well into weird, check a couple of items from creepy and make one attempt (albeit unsuccessful) into irredeemable
Okay, on the flashlight tier scale, Dollar Store, etc. should actually be negatives. Points should be deducted. Not one added to your score, but points subtracted.
On the hot pepper topic, it’s not always the heat going in that makes the difference. That’s all I have to say about that. :zipper_mouth_face:
