For the new Flat white, Does anyone know what the model number would be for the “perfect” version?
I am thinking about sending it to a manufacture I am working with for a new light but obviously want them to get the best version of the LED if possible.
I did not see a model number break down in the datasheet like some LED’s.
I believe for the tint bins you just specify the Color Chromaticity Groups on page 6 of the spec sheet. fcbB46 is the warmest but is entirely above the BBL so will be greenish. The ebzB46 is 2nd warmest and is just a tad bit under the BBL but might still look green under reflector/optics. The ebxD46 is 3rd warmest and is what Led4Power is selling , which I think is the best tint bin since even in any reflector/optic, it will still not be green.
Led4power sells the 6N flux bin. The highest is 7N so would be sweet if the flashlight manufacturers can procure those since they are buying in large quantities.
Will be sweet if they can acquire that! But even the 6N bin from L4P has been pretty stellar. I just did a search for this emitter and found two other places that sell them.
Mouser sells the KW CSLNM1.TG-8M7N-ebvF46fcbB46-15B5, which basically means it can be any flux bin from the lowest 8M 250lm-280lm@1A to the highest 7N 355-400lm@1A, any chromacity bin from the coolest ebvF46 to to the warmest fcbB46, and any forward voltage group from the lowest “15” 2.75V-3V@1A to the highest “B5” 3.25-3.5V@1A. Why would anyone want to buy from Mouser with so much uncertainty?
Avnet sells the KW CSLNM1.TG-6N7N-EBVF46EBXD46 which has tighter specifications 6N to 7N flux bin and the cooler two chromacity bins, but it doesn’t say what the forward voltage group is.
I’m surprised how a small shop like L4P was able to obtain superior binning than the bigger folks.
SVK, I think that Mouser simply puts in a bulk order and does not really care what they get, they just want something with maximum margins so they can see the demand. They rarely have the best bins or tints of any LED.
Agro, Interesting, what footprint are those? 3535? Do they also have a neutral thermal pad? That is what is making me consider the white flat. The black flat was just too much hassle to work with.
The boost HX (real name CULPM1.TG) is just a larger version of the CSLPM1.TG with better cooling for more power capability.
No reason to get a CSLPM1 when the boost HX is announced.
The CELNM1 is the same thing as the CSLNM1 but with a smaller and non-square package with worse cooling. The only reason it seems better on the datasheet is because they list an extra bin, and it’s pretty much impossible to get a high bin from the osram LEDs because they are sold in ranges of bins.
It will simply overvolt worse than a white flat would, and be very difficult to find a PCB for.
Basically the second letter is the physical size of the package:
E = 1915, S = 3030, U = 4040
The fourth letter is the size of the die.
N = 1*1 = 1mm^2, P = 1.25*1.6 = 2mm^2
Do you have a model number for the Boost HX? What performance do you expect? For some reason I can not view any datasheet from their site, the PDF just refuses to download.
Funny, I just impulse bought 4 of the CSLPM1.TG from mouser last night. Looks like I bought the first 4. Can anyone tell me how the mouser bin compares to the ones available from led4power? I couldn’t make sense of the order code.
