When hiking at night, I always bring with me a “neutral” tint zebralight with a home made diffuser, but i would kill for a warmer, higher CRI tint and this awesome light distribution.
In my scenario, i would bring this lantern instead of a powerbank, and use the battery as emergency charger with a tiny magnetic battery->USB dcdc converter.
Would it be possible to include USB output inside this tiny monster? Even a 500mA cheap circuitry would be enough, for those like me that are concerned about backpacking weight and love multipurpose stuff.
Maybe, if there is no space for a full usb port, an USB otg adapter could be used if the circuitry inside the lantern could support it.
Anyway, really cool stuff, guys.
Thanks
Edit
Just read part of the thread, it appears that the powerbank function was dropped.
Well, i understand, still interested, I’ll have to bring extra gear and will not be that simple, but it’s all right. Maybe I’ll mod it
Interest list update time, and welcome to more new members who’s first post was interest in this light, including Alexkram, Odyessus, Rascto, Jensen, and Arthur.
Also second post expressing interest in the lantern by blgrssby and K1NGP1NT.
I'll wait for V3...... kidding of course. V1 sounds more than good enough for me and if a V2 comes about and is a useful upgrade, may get that one too.
Once the production model is available, and if it’s even equal or better than the Prototypes i have built so far, ( Proto-V1 & V2 i have & use now) then the production BLF LT1 lantern will still be better by far than any other consumer lantern i have tested, used and seen in stores or online.
why not? if you own a digial camera,DSLR or a fillin light etc(most have alum bodies) and you have a tripod or monopod then you would do it without even think about it!!!
Tripod screws are always coated with nickel or zinc so you don’t have to worry about corrosion, and female threads are stronger then male threads so there won’t be a stripping problem. Every aluminum engine block and head has steel fasteners threaded into it.
