When I was trying to estimate what all these emitters would output I was figuring theyād pull some 86A to get around 25,000 lumens. At a guesstimated 3.4V on the average, maybe a bit higher, yeah, itās a lot of power. A scary lot of power! I was going to add in 4 Nichia 219Cās but the 106A resulting draw was probably going to be too much and in the end I left them out.
My wife and daughter bought me a T-Shirt on one of my birthdays, years ago, that reads āI Do Know It All, I Just Canāt Remember It All At The Same Timeā And while knowing it all is a large stretch, the part about what I can remember of what I should know is spot on!
I donāt know what Iām doing. I get lucky a lot.
Edit: When I built my Meteor M43 with 3 slaves to the one master, I got an actual at-emitter current draw reading of 58.8Amps from the 4 cells. That one has 12 Samsungs. So yeah, this one is seriously gobbling up some current!
I put off getting a smart phone for a long time, but now I have a pretty new Apple i8, the camera is decent and I have an app to let me fully control it. That said, I thought I could step outside and get a quick beamshot without grabbing a coat and going the full camera tripod route. Maybe I was wrong. My phone doesnāt quite know what to make of thisā¦
The white barn with the Flag flying at 610 yds distant is visible in the background, if you can get through the foreground.
I actually bought Carclo 10mm Optics to go with the Nichiaās I had but I needed the space for the wiring. I probably could have wired it differently, but still, didnāt want to piggyback them onto one of the existing 5 drivers and there wasnāt room for a 5th slaveā¦
@Dale, great light canon. More pic once you get that iPhone figured out
My mod went the other way towards a tiny light.
I liked my new Olight i3T well enough to dedicate one of my last remaining Nichia 219BT SW45K R9080ās (but I apparently didnāt like it enough to leave it alone cool tinted; yes, Iām a tint snob )
Hereās a peak at the inside, thatās a Philips LUXEON TX CW -
I replaced -
the Philips LED board with a copper MCPCB for the Nichia, and
the plastic lens (which got destroyed in the mod process) with a glass lens.
Now thatās itās done, this simple 2-mode light has managed to āwarmā itās way into my heart (beautiful neutral white) and into my pocket as an EDC!
On the basis of what I had to do to get inside :weary: I can vouch that the i3T is built to be fairly water and drop resistant.
What attracted me to the light was the runtime & regulation they managed to squeeze out of an ordinary AAA and the forward clicky. And now with a great tint, itās a tri-fecta :+1:
It took a 10mm mcpcb. The Philips Luxeon PCB was not reuseable/reflowable as it has different footprint than typical Nichia/Cree 3535 X-type (itās also not metal core). Same for the lens, the few things I tried didnāt work, including taking heat to the lens to soften any glueā¦that only distorted the plastic lens :person_facepalming: after which it didnāt matter any more. Fortunately I had a salvaged 12mm glass lens I was able to use instead.
As far as I could tell thereās nothing to unscrew. The LED & lens assembly appear to be press fit and/or glued in. This light does not appear to be built to be modded/serviced but then thatās what makes it more robust.
Unlike most other AAA lights Iāve tackled which typically involve a small pill that is complete with driver and LED MCPCB, the i3T is designed more like some larger lights using an integrated shelf. Hereās a peak under the LED PCB, the shelf facilitates direct heat transfer to the body.
I removed it by inserting a tiny thin mini-screwdriver in from one side and wigging side-to-side to break any bond/glue. Once the bond/glue was loose, it pried out.
Perhaps if done carefully, one could salvage the soft plastic lens for re-use (sans any damage to the edge where the screwdriver went in) but in my case it was already deformed from trying heat so I made no attempt to preserve it.
Afterwards one could either try pressing the lens back in or replacing it with another, in my case I did the latter with a glass lens that I glued in.
On my big Quad quad plus one light, I was looking at the empty spaces this morning and trying to figure out how to finish that offā¦ Two of the 4 spaces have a āTā intersection of the 18ga Teflon positive wire crossing the 14Ga Red Turnigy, so that needs to be sealed and capped. So I got to thinking, and looking aroundā¦. I would like to use 2 of the Sofirn carriers with 8 cells when all is said and done, so it will be 8 18650 cells powering up 5 drivers to 4 Quads and the output really hammers, right? So I found a new cartridge developed just this year for a specialized custom AR-15ā¦ the .458 HAMāR! Iām inquiring with brass companies to see if I can get a few pcs of this brass to fit into the voids here, maybe even put small SMD emitters in the primer cup and run these with the switch light for a glow up top. I can use Sugru (uncured Silicone) under and around the electrical connection and also to glue in a cut down .458 HAMāR brass cartridge such that the headstamp is up against the lens like the Quad optics and center reflector. Lighting it may be more than I want to bite off, but I could certainly fill the primer cup with a glow in the dark powder and cut a window in the side of the cartridge to allow this powder to charge when the lights are illuminated.
Anyone got any once fired .458 HAMāR brass laying around?
Richard managed to de-dome the SST-40 and then he sealed it with LED Seal to protect the bond wires. Iāve never used the stuff, but it appears to be a clear almost epoxy like stuff that is put on like one drop, it spreads and covers the die and bond wires and leaves a thin durable coating, like a micro dome.
