Yes.
Interested
Freeme did they incorporate any of the feedback from Maukka?
Been a while, don’t even remember signing up. Let me check this out and see if still interested.
Recommendations:
- improved UI with ramping option. Still working on it
- smoother reflector. Confirmed
- larger inner diameter for its reflector for tighter hotspot. Unlikely to happen
- 21700 flat top support. They are looking into it. Either redesign or omit the reverse polarity protection insulator
- make S/S bezel available for the light or at least an option for separate purchase. SS bezel will be available for purchase later
- Protected 18650 will NOT be supported
Deal is active NOW!
Code received, order placed.
NW order placed
Oh goodie… Can someone please help me? I have a Rofis 21700 protected cell that I want to use in this light. Will it fit?
If not I will have to order a cell from AliExpress because Banggood doesn’t ship bare cells to South Africa.
Unlike previous ASTROLUX group buys, FT02 deal will only be valid for 30days!
Recommendations:
SKV89:Freeme did they incorporate any of the feedback from Maukka?
Nevermind, just read this post *sad face
Too long.
Oh goodie… Can someone please help me? I have a Rofis 21700 protected cell that I want to use in this light. Will it fit? If not I will have to order a cell from AliExpress because Banggood doesn’t ship bare cells to South Africa.
Just placed an order for one. Thanks!
Ordered, Thank You!
Interested
What about updates to the quiescent current draw? And low lumen efficiency?
Ordered 1 NW, ty
Thank you for your support!
Interested
Ordered, Thank You!
Ordered 1 NW, ty
You can either remove the white polarity protection disc to make your flat top work or else add a solder blob to it.
It is the length I would be worried about.
Edit: Yeah, I see that Freeme says it’s too long.
You could make that cell work by removing the protection circuitry and adding a new wrapper.
Interested!
Done. With the PCB the cell measured 75mm. With the protection circuit removed and solder blob added it now measures 72mm. Should fit, right?
