NITECORE MH25GTS XHP35 HD 1800LM 8Modes USB Rechargeable LED Flashlight + 3500mAh 18650 Battery
Coupon code with sizeable discount is available.
» Request via PM here«
Nitecore MH12GTS XHP35 HD 1800LM 5 Brightness Levels 3Modes USB Rechargeable LED Flashlight 18650
Coupon code with nice discount is available.
NITECORE EC4GTS XHP35 HD 1800LM 8Modes Unibody Compact Long Thow Searching 18650 Flashlight
Coupon code with very nice discount is available.
Wuben E05 XPL 6Modes 900Lumens Magnetic Tail EDC LED Flashlight Reading Light with Diffuser 14500
Coupon code with very good discount is available.
Use coupon code BGRTW to get $12.99 price ($19.99 / –35%).
Neutral white and cool white options available, accepts 21700 cells.
Lumintop BLF GT mini XPL HI 1200LM Stepless Dimming Portable EDC 18650 LED Flashlight
Use coupon code AC18 to get $34.65 price (-$14.85)
Offer valid until November 24th.
4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery
Use coupon code AC18 to drop the price to only $15.39 (-$6.60 / –30%)
These are ideal (and recommended) for BLF Q8 and other high power lights.
Offer is valid until November 24th.
4PCS Samsung INR18650-30Q 3000mAh Unprotected Button Top 18650 Battery With Protected box
Use coupon code AC18 to get $16.09 price (-$6.90 / 30% off).
This cells pack include plastic protective box and therefore can be shipped to more countries than bare cells.
Ideal (and recommended) for BLF Q8 and other high power lights.
That’s a good deal. I ordered!
I’m in California and it says they can’t ship these cells to me?
Did you try to order the ones in the plastic case?
‘user’ error, my bad. Works now. Thank you.
Convoy S2+ Nichia 365nm UV UV LED 1Mode OP Reflector Flashlight
Use coupon code AC18 to get $20.26 price (-$8.69 / –30%).
Astrolux S41S Stainless Steel 4x Nichia 219B/XP-G3/G2 A6 1600LM Mini LED Flashlight
Use coupon code AC18 to get $23.06 price. It’s already discounted *59* and this coupon gives another 30 on top of that so don’t wait as this might end quickly!
Best price to date!
Matching 18650 extension tubes
using coupon code 8a955d prices drops from $11/$9 to $9.35/$7.65 (–15%)
*To be able to use both codes separate orders need to be placed.
Nitecore Intellicharger NEW i2 Battery Charger For Li-ion/IMR/LiFePO4/Ni-MH Battery
Use coupon code AC18 to get 30% discount (-$5.09) and a final price of only $11.86
This is a very versatile charger supporting Li-ion, LiFePO4 and Ni-Mh/Ni-Cd chemistries. Has the ability to be powered either by AC adapter or 12V car adapter.
Convoy S2+ 7135*8 Driver XM-L2 U2 T6 1100LM 3/5Modes Super Bright EDC Floodlight Flashlight
Use coupon code AC18 to get $15.39 price (30% discount / -$6.60) for all colors and LED options.
3 NEW COLORS and 4 LED options = 12 new combinations
The purple one looks especially suited to host UV pill - direct swap from the above Convoy S2+ Nichia 365nm UV LED
Use coupon code AC18 to get $14.70 price (21.00 / -$6.70 ).
This is recent 2.0 revision of tool AA. Manufacturer claims 18% increase in lumen output (~100lm more) and 15% increase in range over previous version.
It’s now 650lm on 14500 li-ion cell and 270lm on Ni-Mh AA and has 4 modes and hidden turbo(need to cycle power 5-6 times to activate). It’s also slightly shorter (by 2mm/0.08”) and lighter.
Use coupon code AC18 to get $15.01 price ($21.45 / -$6.44)
2 LED tints available: 1A (cool white: 6000K-6500K) and 3B (neutral white: 5500K)
