DARKSIDE | NYMPH (10440 twisty Fet+1 flashlight w/ 4k 9050 219C)
The turbo starts slowly ramping down after more like 5 seconds and ends up at mode 5 level after 20 seconds or so. Lumens measurements are usually taken at the 30 second mark. Instead of giving run time measurement from a continuous run, which would not be much different than mode 5 run time in that case, I ran the turbo multiple times for a total of 30 seconds each time. You can cycle the turbo 8+ times this way before lvp. There’s probably a better way to word it.
OH, so its the “number of cycles/runtime” equivalent for the turbo mode.
Does it take another 6 turns from mode 5, or just 1 to jump back to turbo?
Just 1 turn and it’ll do the turbo blast again but only if you let it go 20 seconds first.
It’s probably going to end up with thermal regulation rather than a timer though thanks to switching to a more capable mcu.
Sounds good, im good with either flavor though, I just want this to be a success!
Is there a glass lens to protect the TIR or has the bare TIR been resilient enough ?
I do not see any glass in mine, but I have carried it a bunch loose in my pocket and have not scratched up the TIR. PMMA TIR’s seem to be very tough! Olight has been running the bare for years and most of mine are still in very good condition.
As a plus, the opening at the bezel is so small that most coins and such can’t enter the bezel to scratch the optic. :wink:
Very true.
From Kickstarter:
I thought this was a nice touch
There’s actually an entire robot set up for that. It tests the voltage sensor on each individual driver, modifies the firmware, and flashes customized code to each driver. It’s pretty fancy.
The thermal algorithm in Crescendo should work reasonably well on this, though it doesn’t have the smooth adjustments of Anduril. Anduril’s algorithm is smooth but still needs some fixes before I’d trust it on such a small light. I suppose I should just bite the bullet one of these days and rewrite the whole thing.
Aw, no pics? Thats such a tease. Might be better left as a secret.
Id like to see a nymph raw or clear anodized, curious how that would shine.
Well, were almost halfway there, still have a ways to go though. I might be upping my contribution if not doubling my order depending on how things go.
I haven’t seen it either. I only heard about it.
I figured the normal method would be used — manually measure a dozen drivers or so, take an average, and use the same values on each. But I guess there’s an automated rig set up to flash the battcheck firmware, run it at specific voltages, count the blinks, compile the real firmware with those values, and then flash it again for real.
Well, were halfway there with 10 days left. Im hoping for the best as this project has really grown on me.
Might actually double my backing depending on how things go.
This is an awesome light, hope to see it for sale soon not on kickstarter. After being burnt by the Znaps and another kickstgarter project that never came through I don’t waste money on kickstarter anymore!!! It is a wonderful looking light and looks like you have put quite a bit of effort into it!!
If this were some random guy on Kickstarter, I’d be wary too. But it’s not. This is Hoop, not some anon who just wants to take the money and never deliver anything. If the money is transferred, he’ll deliver the items. The R&D is already done, with working items already out in people’s hands. Some Kickstarter projects are pretty high-risk, but that’s not the case here.
If I had the money, I’d pay off the other half of the Kickstarter myself. This light is worth being manifest. Sorry I’m poor. :weary:
You have successfully backed DARKSIDE | NYMPH
I’m in, this thing needs to be brought to life.
Hoop: interesting Kickstarter project :+1:
I hope you succeed, and joined as a backer as well.
Well guys, were down to the last ~48 hours. $5900/9000.
Im still optimistic, hopefully there will be a surge to push it over. We will see.
I just don’t understand how this level of work get’s overlooked, I find it amazing and virtually intoxicating, can’t resist.
Still hoping for the best… best of luck Hoop! :slight_smile:
