Glad I could help
Hope it stays fixed, for the build at least :+1:
Great fix! As CRX said, I hope it stays fixed.
Print some new wheels whilst it’s working well…. :innocent:
I’m struggling with the prints. The outside of the lower casing - printed in ABS during about 10 hours - looks fine (the small 0.2 mm layer on top for better print bed adhesion is supposed to be sanded down). The inside is bad though. Wall separation everywhere, even the threads for the bottom plate ripped of partially. Not usable, I guess.
I’m expecting new PTG filament today, its supposed to provide better layer bonding. Haven’t used PETG yet, I hope i can handle it without too many problems, since contest time expires.
And I’m still waiting for LEDs, magnets and o-rings from China.
Especially sad to have that happen after having to wait 10 hours for the printing to complete. At least when I make an error cutting wood I know about it right away. I hope the new stuff works better.
So do I. Got it this afternoon, made some test prints, and printing of the lower housing with this new PETG is currently in progress. Looks good so far but at that stage the ABS print did also look good. Anyway, I redesigned the housing to print it faster (e. g. got rid of the knurling and made thinner walls) so it should be done after 5 hours at max.
I know it is a failure but the detail you put into the piece looks impressive.
Whatever you do, 3d printing is some weird black magic stuff.
How do you like petg? (Compared to pla?)
Success
I know its not too beautiful but it works. Haven’t printed PETG before and I’m pretty impressed. Of course there was a lot of stringing but layer bonding is pretty tough. This component is only about 37 grams, flexible but strong. As you can see, I did a redesign of the housing. The lower housing is printed in 2 parts now. The outer one has been stripped down to achieve shorter printing times. I omitted the knurling - it did look pretty well but it increased printing time a lot and needs thicker walls, and my spare time is limited currently. I still have to finish the design of the inner part, printing this part will be less demanding since its usually hidden.
@thijsco19: The reason why I’ve chosen PETG over PLA is the higher heat tolerance and the stronger layer bonding.
Hooray!!!
Good to see you work around the problems you faced. Well done
interesting build
Fails and wins printed so far. I’m not sure if I’ll finish this project in time since now I’m too busy with family activities until Monday.
An impressive number of pieces.
Can you share what software you use and how difficult was it to learn? And if you don’t mind me asking, is the use of 3D printing something you do at work or simply something you learned because you are interested? Thanks, I have been curious about 3D for some time, but learn better by doing than by reading.
I’m interested in 3d printing for years now and since it gets more and more affordable I bought my first cheap printer this summer. I tinkered with electronics and software all my life (privately and commercially) and this 3d printing actually offers many oportunities I was missing the past years - particularly since my hand crafting skills and my patience are somewhat underdeveloped. And I have 2 kids who are also interested in this and other technologies.
My first 3d designs I created with Tinkercad which is great for beginners. But soon I was missing advanced options which I found in Fusion360 (free for private use). Tinkercad is easy to learn, Fusion360 is not due to its unique user interface. I had a hard weekend with much cursing and swearing when starting with this software, although I’m a software engineer by myself.
Its pretty easy and encouraging to create and print the first simple designs, and if you learn rather by doing than by reading you should try it. For advanced designs and more beautiful prints you have to do lots of reseach though - but there are many sources of knowledge and many people eager to help, just as in BLF.
In addition to a design software you need a slicing software which prepares the designed object files for printing. It “simply” calculates the path the print head has to go. Currently I use Cura and Slic3er (no typo), they are good but not perfect, and for better results there are many tuning options. Both are free.
You have the makings of a work of art there FM.
Man, after all this I hope you are able to get it together.
Maybe we could all vote for a weeks extension to the comp….
I’ve finally sucessfully printed all large and most of the smaller parts. Since I modified the design and made upper and the lower casing two parts each I was able to use the green ABS for the shells as primary intended. The blue components are made of PETG which is also more heat resistant than PLA.
And I assembled the light the first time right now. Electronics not yet inside. Don’t mind the orange thing in the middle, its just a printed placeholder for the final copper disk which I still have to drill and file. Did I mention my missing handcrafting skills and patience? Fortunately only a small ring of the copper can be seen in the final build so hopefully people don’t notice my handcrafting disability …
Closed lantern:
Opened:
Bottom view (the orange triangle is a printed tool for dis/-assembling):
The electronics compartment. You might notice that the bottom plate has threads at the outside and in the center. This should ensure the o-rings pressed tightly for proper water protection. Magnets still missing, haven’t arrived yet.
Very nice looks like you’re on the home stretch. I wouldn’t worry too much about your hand skills. End product will be awesome
Looks good, Mike
