OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
80kCd in a D1S is underwhelming to say the least, typo maybe ?
I was wondering why sky lumen’s numbers were so different:
320kCd
But that was at 2m and with inverse sq law…
The unit should be klux then, not kcd
He says “in theory it throws more than 1km”, thus I believe he wanted to say “got 80Klx @ 2 meters” which is 320KCd and equals ≈1131.37m of throw.
320kcd under a tiny TIR? nah something is not correct
They talk about about D1S 50mm reflector FL, not Quad D4S.
Ugh yes thanks I see now
I also had opportunity to play with this larger 2mm white flat. Test with classic light meter and clamp meter (so test is just for reference before someone with better equipment test it). Full Samsung INR 30 Q. Single cell 18650 light with FET Djozz driver.
4.2V, 13.4A, 930 FC
4.0V, 12.5A, 950 FC
3.9V, 11.4A,1050 FC
3.8V, 10A, 1250 FC
3.7V, 9.20A, 1200 FC
3.6V, 8.20A, 1150 FC
3.4V, 7A , 1100 FC
Somewhere at 8-9A will be just enough…
The most beautiful emitter I ever had in my aspheric light. When searching at night in zoom in mode with aspheric light it looks like wide screen TV 16:9 format :slight_smile:
But my conclusion this ain’t emitter for single cell fet drivers but you can put it in if you insist and wanna play. Regulation is must if you don’t wanna live on the edge :slight_smile:
Also very robust emitter. It can withstand some serious current draw. Add as thinner layer of solder paste as possible.
Great, thanks for sharing your results. Can you remind us what the dedomed XPG2 does in the same light?
As promised, here are the results with pics of my Jetbeam T6 with the OFW…well kindof….I had a super hard time reflowing one of the OFW. I gave up and put a sliced SST-20…So, there are 3 OFW, and 1 SST-20.
On my Lumems tube:
STOCK T6 With XPL’s
Fully charged nitecore protected 2300mah batterys
3,910 lumens
MODDED T6 With 3 OFW and 1 SST-20
BY-PASSED springs
2,616 lumens
As far as lux goes, I dont feel fully confident in these #s. It was getting late and simply didnt take the time to do a clean and consistent test. I will retest LUX. But for now, here are my numbers.
Measured at 3 meters:
Stock Acebeam K70
Fully charged and tested Samy Qs
412k
Modded T6
547k.
Visually you can see a difference between these 2 lights. Not a huge difference. But definitly noticable.
Link pics:
Can you perhaps provide us with some beamshots showing that? So would you actually recommend this rectangular shape LED for hunting/searching aspherics?
Thanks
950FC 5M
No. Not for mine configuration 1x18650 light fet driver.
But if you can get lets say 2x18650 aspheric light with buck driver than yes.
Once upon a time,there was a Zaxman Z1 zoom aspheric light, which had 2X 18650 I think.
Nice!
The four beams certainly look cool!
Received my CSLNM1.TG after close to a month. It’s running with the A6 driver, since it’s cheap and easily available. Managed to get ~900 lumens and 640,000cd (1600m). Tried shooting at a building ~870m away with light pollution and I can definitely still see it hitting the building. Thing is a beast.
EDIT: Remeasured and centered, got 340kcd.
Beam comparison with BLF Q8 LH351D and L2 White Flat
How is the tint compared to a Cree 1A tint? Is it warmer, cooler? Can someone please post a comparison beamshot between a 1A or 1C Cree tint and this Led?
Thanks in advance!
