UTorch SF01 price drop to $6.99
71 posts / 0 new
bidas
Last seen: 11 hours 40 min ago
Hi to all, i received my Utorch SF01 yesterday, and i’m being testing it.
I can confirm that it work with AA, AAA and CR123A. It’s a bit tricky to put in the AAA, you have to center it well to make electric contact but once closed i can shake it hard without any problem( a very stiff spring keep it in place).
The LED seem a cool white Cree XP-G2( in the manual title says CREE XR-G2, gearbest says XR-E, maybe a mix of XR-E with XP-G2 Big Smile ), I tried to unscrew the head but didn’t managed to, yet!
This flashlight really is a streamlight copy it even has the same TEN-TAP® Programming from streamlight:
three different operating programs:
1) high/strobe/low 2) high only 3) low/high
Visually i only see the two differences from the PROTAC 1L-1AA, the knurling in the tail cap and having just 3 instead of 4 fins around the head.
Tail cap currents:
CR123A:
High 0.884 A
Low 0.335 A
AA:
High 1.41 A
Low 0.430 A
Some photos:
Utorch SF01 album
hank
hank's picture
Last seen: 14 hours 8 min ago
It’s cheaper now.
Has anyone said whether it has mode memory? (searching “mode memory” in the thread doesn’t find any info)
bidas
No memory mode, is momentary On(forward clicky), Programmable with 3 different programs: 1) high/strobe/low 2) high only 3) low/high.
DavidEF
DavidEF's picture
Last seen: 2 hours 48 min ago
Does it seem to be well made? I’m thinking of getting a couple of them to give away. I don’t want to give junk. Big Smile
- The YKK Philosophy
wle
wle's picture
Last seen: 1 day 13 hours ago
ui seems to be high , low , or strobe
high may be 350 lumens [seems like that would last about 5 mins with cr123a]
they don;t say what low is
wle
--Daniel Behrman, "The Man Who Loved Bicycles".
--Greg Lemond.
              __o
    __o     _`\<,_      __o
  _`\<,_   (*)/ (*)   _`\<,_
bidas
You can program it like the TEN TAP from streamlight, they copy everything… for me high seem more like 300 lumen with cr123a, i test it last night with ceilingbounce app and i didn’t see any drop in the first 71 minutes i had only one cr123a home and i use it to measure tail cap currents before, and other tests so was not completly new.
Low seems like 60-70 lumen on cr123a
High on AA around 150 lumen
Low on AA arround 40 lumen
bidas
Good enough for the price but don’t expect miracles, threads are triangular not square, didn’t come lubed, lens not AR coated and reasonable SMO reflector. But LED seems a original cree xp-g2, good springs and switch.
pennzy
pennzy's picture
Last seen: 3 min 11 sec ago
Can 16340 or RCR123 be used?
bidas
Probably not, didn’t test it because the info i gather says i doesn’t work and i don’t wanna “blow it up” … other think is that i didn’t manage to open the head(meaning didn’t see the driver yet)
pc_light
pc_light's picture
Last seen: 11 hours 24 min ago
I’ve run for a while (minutes) on 16340 without issue. no smoke or LED discoloration. All modes work with brighter levels but can’t say about long-term usage,
Seeking the light.
bidas
Finally tested it with a 14500 and a 16340 they work and they are brighter I estimate around 450 lumen @ 1.32A(tail cap current). I tested it briefly I don’t know how it will handle the extra power and heat…
pennzy
pennzy's picture
Thanks for trying them .
Barkuti
Barkuti's picture
Last seen: 25 min 7 sec ago
0K, so that Utorch SF01 @ GB can take CR123/16340s, AAA/10440s or AA/14500s. From the above comments I can infer it may use a boost/linear hybrid driver. However, does it implements some sort of low voltage warning or cut-off? Piece of shit cake AA/AAAs plus one run and dump CR123s specs cell support tells me it may not, which is a bummer. Flat Stare
For the above people sticking li-ions inside beware: boost/linear driver will continue boosting and discharging li-ion/LiFePO4 cells maybe without too much discernible change in output until voltage is down to harmfully low levels, for li-ion cells at least. This is the same crap which happens with shooting range meat cheapass SK68 flashlights. Big Smile
Cheers Party
nottawhackjob
Ok so why not use only protected batts if unsure what’ll it do and leave the batts with the job of protecting themselves regardless of whatever this driver attempts. Should I try it with a protected 14500 outside in the middle of a concrete pad in a steel bucket? Facepalm
Then again, maybe this particular hybrid driver won’t do that to a protected lion batt. Unprotected IDK. Buy one yourself for $9.99 and report back to us! Smile
“In many things in order to truly understand the small picture you have to understand the big picture first.”
wstrachan
Last seen: 2 days 12 hours ago
Rechargeable cr123 based cells are an issue because the button top protected ones are too long and the light won’t function without the tailcap loosened a couple turns. If you use a protected cell, use one that is equal in length to a standard store-bought cell.
I sold mine for a few bucks so I don’t have one to test thoroughly but the contact issue is what happened to me. When I swithched from a rcr123a to a regular 123a it worked fine.
light addict....yeah I've got the bug.
Atrolux MF02_O2S
Imalent DT70
Emissar (All Models)
Lumintop ODL20C
Wuben A21 & T70
thrunite tn32 ut
acebeam k60
many, many others...
nottawhackjob
wstrachan wrote:
Rechargeable cr123 based cells are an issue because the button top protected ones are too long and the light won’t function without the tailcap loosened a couple turns. If you use a protected cell, use one that is equal in length to a standard store-bought cell. I sold mine for a few bucks so I don’t have one to test thoroughly but the contact issue is what happened to me. When I swithched from a rcr123a to a regular 123a it worked fine.
Wait a second. Contact issue? If I can run a AA and the tail cap fully tightens then how come ya can’t run a shorter rechargeable cr123 cell? Grad
Also this light can’t work if the tail cap isn’t fully tightened to begin with. Btw I think you meant that the light won’t function WITH the tail cap loosened a couple turns. Which is true. Again, this light must be fully tightened for it to contact the tube and close the circuit anyway.
I sometimes cut a coil or two off tail cap springs if I think there’s excessive/unnecessary pressure on the neg batt anode. On this light if one plans to run AA length size batts it prolly wouldn’t hurt.
bidas
When using rcr123/16340/cr123 this flashlight has a fixed holder on the positive end, this holder is larger than the AA so you can push it down, so rechargeable protected cells witch are longer than cr123a may not fit. I test it with my only button top ORB1607 from my OTR U16 flashlight and it works, but this battery are not protected so i don’t recommend using it(this driver will keep draining the batteries, it’s not made for rechargeable li-ion), with my flat top 16340 don’t work(don’t make contact). Other option is using protected 14500, i’m running it with a soshine 14500 protected cell… one disadvantage of the 14500 or AA cells in this flashlight is to be a bit harder to screw the tail cap while pushing down hard at the same time.
FlashlightDeals
Last seen: 8 months 4 weeks ago
See the first post for an even lower price for 11.11
Paul59
Last seen: 5 hours 28 min ago
Just ordered a 3-unit combo for USD 9,99 / EUR 9,23 from GB Smile
Henk4U2
Henk4U2's picture
Last seen: 13 min 57 sec ago
Sorry to interrupt your tech-talk, but I just bought this light for $4.99 (€4.45).
Use the coupon code: GBQCSF01N when the light is in the cart.
Had to pay €0.74 for shipping, however.
More info, follow this link to Reddit.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Paul59
Three SF01’s for $9,99 sounds better to me Wink Use the 3-units combo offer/promotion, no code needed.
mrheosuper
Last seen: 6 hours 42 min ago
this is a steal, i just order 3 for 10$ and i want to order another 3 Facepalm
Forgot my pen
SIGShooter
SIGShooter's picture
Last seen: 4 hours 20 min ago
FlashlightDeals wrote:
GearBest asked me to share a promotion they’re running, the Utorch SF01 is on sale for $9.99 with the code GBUtorchSF01. This light claims to be compatible with CR123, AA, and AAA batteries, which would make it a great backup light.
I believe it’s CR123 only.
It would be extremely strange if it worked with CR123, AA, and AAA batteries.
That’s what I thought, but my person at grrarbest says it works .Can’t find any review to confirm .
This youtube review shows an Enloop Pro being inserted into the flashlight and then being turned on. The review on the SF01 starts at 5:15 and the insertion of the AA battery is at 7:20.
Not the most professional of reviews but at least it shows it working with a RCR123A and an Enloop.
Henk4U2
Henk4U2's picture
My wife would agree with you. She probably would buy much more of them to save much more money.
I just spent less on 1 light that only made me curious, probably can’t EDC and certainly won’t give away.
I only buy/give away lights that run on primaries if they are to be meant for a keyring or have a vampire driver.
So I don’t throw away anything that is not totally depleted (hmm, almost sounds like I’m a married woman Evil )
Lim_Wee_Huat
Last seen: 2 weeks 2 days ago
Arrgghh.. 3 XP-G2s for $10.. there’s less than 100pcs left. With clip + pouch included and it’s programmable. While still waiting for 2nd batch of Sofirn’s C01.. sure, why not? Smile
pennzy
pennzy's picture
I could not resist 3 for $9.99 either. Probably use for stocking stuffers. Has anyone used lithium- ion for any extended time in one of these yet? Might try a protected 14500 in one for giggles.
Nicolicous
Nicolicous's picture
Last seen: 3 min 55 sec ago
i gave mine a full run on high mode with lithium battery and it’s not an issue at all.
it gets warm and i would of guess around 45 degrees? (sorry i left my temperature sensor at my parent house)
Nico -.-
pennzy
pennzy's picture
Thanks for the report on that. I will give mine a try when they come.
vit55
Last seen: 2 days 22 hours ago
3 for 9.99 sold out
Satan@103TFS
Last seen: 1 hour 7 min ago
3 for 9.99 not work for me I add 3 SF01 to cart but the price show 26.97 don’t know why.
