They talk about about D1S 50mm reflector FL, not Quad D4S.
Ugh yes thanks I see now
I also had opportunity to play with this larger 2mm white flat. Test with classic light meter and clamp meter (so test is just for reference before someone with better equipment test it). Full Samsung INR 30 Q. Single cell 18650 light with FET Djozz driver.
4.2V, 13.4A, 930 FC
4.0V, 12.5A, 950 FC
3.9V, 11.4A,1050 FC
3.8V, 10A, 1250 FC
3.7V, 9.20A, 1200 FC
3.6V, 8.20A, 1150 FC
3.4V, 7A , 1100 FC
Somewhere at 8-9A will be just enough…
The most beautiful emitter I ever had in my aspheric light. When searching at night in zoom in mode with aspheric light it looks like wide screen TV 16:9 format
But my conclusion this ain’t emitter for single cell fet drivers but you can put it in if you insist and wanna play. Regulation is must if you don’t wanna live on the edge
Also very robust emitter. It can withstand some serious current draw. Add as thinner layer of solder paste as possible.
Great, thanks for sharing your results. Can you remind us what the dedomed XPG2 does in the same light?
As promised, here are the results with pics of my Jetbeam T6 with the OFW…well kindof….I had a super hard time reflowing one of the OFW. I gave up and put a sliced SST-20…So, there are 3 OFW, and 1 SST-20.
On my Lumems tube:
STOCK T6 With XPL’s
Fully charged nitecore protected 2300mah batterys
3,910 lumens
MODDED T6 With 3 OFW and 1 SST-20
BY-PASSED springs
2,616 lumens
As far as lux goes, I dont feel fully confident in these #s. It was getting late and simply didnt take the time to do a clean and consistent test. I will retest LUX. But for now, here are my numbers.
Measured at 3 meters:
Stock Acebeam K70
Fully charged and tested Samy Qs
412k
Modded T6
547k.
Visually you can see a difference between these 2 lights. Not a huge difference. But definitly noticable.
Link pics:
Can you perhaps provide us with some beamshots showing that? So would you actually recommend this rectangular shape LED for hunting/searching aspherics?
Thanks
950FC 5M
No. Not for mine configuration 1x18650 light fet driver.
But if you can get lets say 2x18650 aspheric light with buck driver than yes.
Once upon a time,there was a Zaxman Z1 zoom aspheric light, which had 2X 18650 I think.
Link pics:
Nice!
The four beams certainly look cool!
Received my CSLNM1.TG after close to a month. It’s running with the A6 driver, since it’s cheap and easily available. Managed to get ~900 lumens and 640,000cd (1600m). Tried shooting at a building ~870m away with light pollution and I can definitely still see it hitting the building. Thing is a beast.
EDIT: Remeasured and centered, got 340kcd.
Beam comparison with BLF Q8 LH351D and L2 White Flat
How is the tint compared to a Cree 1A tint? Is it warmer, cooler? Can someone please post a comparison beamshot between a 1A or 1C Cree tint and this Led?
Thanks in advance!
640 kcd =
Good job on the centering of the led, did you take special measures to get it right?
Nope, I didn’t bother centering the LED and surprised me when I took the measurements. But there is some kapton tape inside even though I know there won’t be any shorts, but I’m paranoid so better safe than sorry. The reflector probably sits a tiny bit higher because of that.
When I was done building, I thought “huh, that was easy” and was really skeptical of my measurements but I tried measuring a couple times and they were all consistent.
What distance did you measured?
680-713lms at 4.5-5.5 amps 6-7amps didn’t produce any more out put out of any single emitters I built and 2100lms at 14.5-15amps out of a triple. I have 9 of these emitters and only 1tested at 730lms the max I could get? I run them on 2S 3v 4.5-5.0 and 5.5amp buck drivers and a ramping D4v2 FETDD and a FETDD Guppydrv3 with the FET’s changed out and 24awg leads, no driver spring bypass drivers. All purchased from Led4Power on 16-20mm boards and 3 singles for the triple. My favorite is the custom M3 single 18350 Flat White with Fast-2-Gun rail attachment.
The hot spot is actually much smaller the corona is about half of the diameter, as the camera dose not quite capture it correctly, it’s is clean and tight in real life, and throws like hell for a 35x30mm reflector, You can see the beam as it lights the Stop sign a full city block down with out a problem even with all the street and house lights on in my hood!
I’ll run it on my Colt M4orgery for kicks…
Pulled a 22mm linear driver (14x7135 I think?) from my Enogear EC21/Nightwatch NS02 and put it in my Jaxman Z1 with a white flat. I magic smoked it on the first try too from over tightening the ring above LED.
~4.85A tail reading for 384kcd measured at 5 meters.
I wonder what results will be if these high cd flashlights measured at 15-20m. Just my mind working. if you read a super range thrower at 5m a very nice number but at 15-20m read much lower numbers you read wrong. Because the beam focused to 5m. And at bigger distances it will widening out and loose intensity. I always measure throwers at 10-15-20-25m and try to focus the light to get the highest intensity at 20-25m readings.
I’ll try to do that when I have the time. I managed to get 1600m. I compared the beam to an Olight M3X and it blew that out the water. Also compared it to a Nitecore TM38 and beam was still tighter though.
