(Sofirn really should cut down on the model suffixes, decide on one way to iterate, and stick to it)
+ATR
+Battery indicator in switch
+CR123A compatibility
+other unspecified changes improve reliability
+Gold and Silver finishes
-v2.0 driver loses the electronic lockout
-Reduced output in Turbo mode in exchange for longer run time and stability
Fine light, good service, but like I said above, when even light enthusiasts have trouble sorting out all the models and their differences, it's a problem.
I received a gold SP32AV2.0 today. Shucks, I did not anticipate this group buy.
But let me encourage those of you who are interested in this light with some observations:
What I like about it:
Looks very nice – a rich, titanium gold.
The build quality is rugged. Feels like it could be passed down a generation.
Nice balance between flood and throw.
Bright. One of the brighter single 18650 EDCs out there.
It retains its brightness on Turbo much longer than a D4. I did a simple test, starting both on turbo simultaneously with fresh identical batteries. While the D4 started out far brighter, after 30 seconds, the SP32 v2 was much brighter as the D4 had stepped down 5 times.
It is slower to heat up and does not get as hot as a D4.
Very pocketable.
Easy to switch between step and ramp modes: From off, press and hold 3 seconds.
The disorienting strobe is full turbo brightness.
Battery level indicator light embedded in side switch.
Battery charge lasts a long time.
Takes any kind of 18650 - protected, unprotected, flat top or button top.
What I would like better:
A warmer color emitter; this one is 5500K, a little on the cool side of neutral white.
The switch light stayed on for 30 minutes instead of 5 seconds.
All in all, this light is a winner - as is. (Not that you couldn’t mod it better!)
I found ramping to be a little on the slow side - enough so that I wanted to explore the manual 4 steps setting which the light arrives with as the initial setting.
Regarding moonlight, the manual claims it’s 5 lumen. I found it bright enough to search for stuff under my car seats, bright enough to read with, to see a few yards ahead on a dark path, but not so bright as to disturb a sleeping tent mate. It’s a useful level that the manual claims can last 260 hours on a fully charged 3500Mah battery.
Yep, ramping takes 5 seconds; which is a bit slow… but I still prefer it to set outputs.
I totally agree about the moonlight mode, for me it is a usable setting as it is not super low. It is bright enough to be usable in many situations but not bright enough to be a bother to others in close quarters.
The first batch of SP32A v1 had slow ramping (about 7-8 seconds). The later batches of SP32A v1 has ramping of about 3.5-4 seconds (I think Emisar D4 is 3 seconds?) I believe the SP32A v2.0 has similar ramping speed as the SP32A v1.
Yes, regarding the lowest mode on v2, I also find it a bit too bright. I often like a true Moon mode (1 lumen) for EDC flashlights…
Is it really that color in Real Life™, or just the way the pic came out?
Mine’s a sort of greenish-grayish-gold color, hard to describe, especially as it seems to change color depending on ambient light. I called it a sort of “pewter gold”.
I like it, as it’d certainly unique, but hey, I’d love a gold-gold color like is in the pic.
I inderstand what you mean about the color. It picks up and reflects the color of the light around it. My photo was taken under a 2700k (soft white) house lamp. The flashlight picked up the warm yellow. Outside, it is much the color you describe. I think that’s cool!
