Well specs state 1200mAh capacity and cells are marked 600mAh so itās parallel.
Btw I definitely am not arguing against your point that non-standard [cylindrical] batteries suck but LiPOās like that arnt hard to source at all should they fail and Nitecore warranty not cover you (unlikely if itās not user caused). Thatās probably a <$5 pack from a trustworthy vendor like RMRC or other small business US owned RC hobby shops.
The $65 price point sounds completely reasonable to me, putting it in direct competition with the Olight S1 lineup.
The two cells being in parallel is smart. This means half the current is drawn from each cell, so they shouldn't have as many issues as the Olight cells tend to.
It's a bummer that the cells aren't replaceable, but the proprietary cells used by the competition really aren't much better, and to be honest I don't think I've ever heard of anyone replacing a 16340 - if it happens, it's the vast minority.
Nitecore has confirmed that, since the primary goal of this light is to get as much light out of a tiny package as possible, there is no high CRI model planned at this time.
Very nice review. I am still on the fence about this light, mostly because of that screen and the costā¦adding a clock function might make it slightly more interesting, and I would very likely get one if I could get it about the $50 mark.
Iām not totally buying the keychain option, but inside a bag, clipped to the key holder in a maxpedition for example and used as a bag light or emergency back up light, I think that it would be pretty darn good.
A shame the TIR sucks a littleā¦
But i guess they wanted to give this light both a fairly tight beam and some spill.
Very deep TIR by the way.
I wonder what kind of driver it uses.
TIP uses a buck driver.
But this has a high Vf LED, so maybe they use a linear driver.
If so, the max output should be lower on a partially depleted cell.
1200 mAh is a nice bunch of capacity for this size light.
Attractive thingy, silly name thoughā¦
Tupperwareā¦
Bit pricey i.m.o. and i donāt really need a display in a flashlight.
A clock and an MP3 player would have been nice additions, justifying the display.
Thanks for the review and tear down.
Wonder if you have a pic of the electronics.
If thereās an inductor on the PCB itās probably a buck driver, or maybe linear / boost.
Got mine for Illumn yesterday, it was exactly as I expected (but was hoping to be surprised).
Itās a carry nightmare unless you lock it out, and if its just in your pocket it is a big lump that sticks out.
Buttons are hyper-sensitive, they are so ready to click, itās kinda funny. No way itās NOT coming on in your pocket.
Power button is almost as far away from your thumb as possible when holding it.
Thereās just no carrying this in the real world without locking it out.
The weight of it makes me wonder if itās empty. It works, so I guess not.
Clip is great, but everything is so cramped on this light youāll probably turn it on trying to use the clip.
In spite of all of that, itās a cool little light! Got a great GB price on Illumn, Iāve know people to spend 2x that and only have a hangover to show for it.
Iāve bought all of the tubular lights one could ever want so Iām usually all-in when a new light that is any other shape is released.
Iāve been struggling to find a use for the ācoulda been greatā Lumintop Geek, finally found something: clip to belt and it makes a fantastic belt light that has no competition!
The Tup will remain on my desk until I find itās true calling. Despite all the negatives, thereās a lot to like.
UI is decent.
Button functions are logical and easy to remember, despite too sensitive.
Stock tint is usable.
Has a strong, fixed clip.
USB port has a boss dust cover.
The screen, the glorious screen!!! Pretty cool having a readout to give you some useful information. We should tell the vape makers thereās money in flashlights and watch what happens.
Will update when I find the perfect use for the TUP.
Oh yeah, I was able to file down the metal tops of the switches on the TIP and make it more pocket-friendly, donāt think Iāll be able to do that with the TUP because it doesnāt have rubber buttons.
I like the TUP UI (similar to the TIP UI, one of my favorite), nice display, nice clip, nice mode spacing, nice battery capacity and light weight.
I can live with the size which is bulkier than typical keychain lights but comparable to a small cr123a pocket light. But those buttons are simply way too prone to accidental activation. One would have thought Nitecore applied the lessons learned about accidental Button Press from the TIP
The Lock-1 feature is relatively easy to activate/deactivate but it would be nice not to have to do so. I actually donāt have a problem with the TIPās buttons, but for those who do/did, stay clear.
My first tweak will be to do something about those buttons. Either raising the area surrounding the buttons or lowering the button height, to reduce accidental button presses taking the light in/out of pocket or clipping/unclipping.
FWIW, here are some photos for size and tint comparison against the TIP CRI. The slight green tint is not nearly as pronouced as appears on screen, but the beamshot image (1-ft distance) is fairly accurate otherwise. Larger cool white TIR-type hotspot with less spill than the TIP.
TUP (on left), TIP CRI (on right)
edit:
TUP after a little Magenta Correction of the TIR for Green
bansuri and pc_light are spot-on in detailing the problem areas for the light. Itās a fun light, I donāt regret buying it but no way is it getting carried in a pants pocket.
For now itāll be close to hand on my desk to grab when I need a quick blast of light (until something else catches my fancy).
Anyone replace the LED on the TUP?
Love the little light and great battery, as usual i cant stand the XP-L HD 1A blue/green mess.
Is it a removable MCPCB for an easy reflow? Or is it glued onto that heatsink/metal band?
Im thinking a high CRI LH351D at say 4000k, maybe 5000K to keep a similar output.
I did exactly that mod. The PCB is easily removable, and itās a pretty straight forward swap. No glue, but that yellow sheet needs to be progress off.
for your information, my nitecore Tup battery is dead after 13 months the battery go down in 5 days even with no use and i get 35 minutes at 200 lumens instead of 2 hours and more
