Fireflies E07 preview
I like the idea of a larger center TIR for better balance of flood + throw.
Forget about bare aluminium.Let's make it in titanium!
There’s a huge number of Chinese ~35mm lenses available, they are used for one of light bulb standards. Unlikely to be exactly the same as Tiny, though it could be compatible. Judging by head diameter I think the lens would be <35 mm.
Titanium is a heat insulator instead of conductor, which is not a good choice for a high output scorcher like this. The heat will get trapped in the MCPCB and internal components will get damaged pretty quickly.
It is a cruel freak of nature that the unchallenged no 1 best material for flashlights is such a cheap and common layman’s material as aluminium.
I don’t like those snap-on/pop-off belt clips at all.
I highly recommend the full circle attachment Solarforce has:
https://www.solarforceflashlight-sales.com/products/solarforce-full-stainless-steel-belt-clip-for-l2-surefire-6p-9p-g2
I completely have the same opinion, plus that a clip that goes parallel to the battery tube (Olight, Solarforce) looks much better than one that slopes towards it.
Is this just your wish or do you have some information, that it will have titanium body (as an option)?
This flashlight looks nice, but as usual, I have (several) different flashlights, that can do the same job, so I don’t really need it… BUT if it was made of titanium, it would be a piece to collect :slight_smile:
In for one, most likely. More accurately, I won’t be able to resist picking one up. Darnit.
I do like the idea of a TIR with a larger center optic, to increase throw a bit.
Larry
I would love to see a full-circle clip in an Olight deep-carry style. Sort of a mix between the picture above and this one:
Except in this case, the clip would be on the tail instead of the head. Starting from the tailcap, it would have a full ring between the tailcap and body tube. Then it bends back toward the tail, turns 180 degrees just before it reaches the back end of the tailcap, and goes forward again. It stays parallel to the body until it dips down to touch the side of the battery tube. Then it slopes upward to provide a place to slide fabric underneath, but it doesn’t go up as high as the long parallel section.
You’re correct. Forget about extremely affordable and easily machinable aluminum for a light as affordable as this. We need to get serious and start looking into flashlights made from diamond, cubic boron arsenide, or graphene.
Has there been any word on when they expect the e07 will be made available? Seems like alot of competing lites in the 21700 format all of a sudden. None seem as interesting as the e07. But my new samsungs are getting anxious.
Silver and gold have good properties too (bonus: bling added). Or else tungsten (why are you limping? I’m just trying to EDC my Fireflies E07)
Photon Fanatic took a square bar of Tungsten, cut it to round, then made a very unique flashlight from it. The weight was obviously more than other lights but not prohibitive. Remember, even with the weight of Tungsten or Gold the flashlight is a hollow tube, not a lot of solid area to make the weight add up. (in other words, even with a much larger light it would take quite the weakling to develop a limp from carrying a light!)
Isn’t tungsten brittle? How would it perform in the thickness we see in common battery tubes? Just curious.
Tungsten can be too hard, making it susceptible to breaking on impact. Brittle? Matter of perception I guess, I’ve been using the same tungsten carbide cutting dies on the lathe for 2 years… Dropping a flashlight made from tungsten most likely wouldn’t break it or show any visible result, slamming it down on concrete might would fracture it.
Been wearing a gold titanium nitride coated W wedding band for several years, wear it working on the lathe, wear it all the time, no scratches and it’s as shiny as new. Anything else get’s beat up pretty quick.
Tisk tisk Dale, wearing jewelry while working with tools? Calling OSHA, please stand by
I suppose you of all people probably have enough tools to cut it off should you have to, lol
The amount of mass that little bit would contribute would be inconsequential to the heat management and/or run-time.
I got married in 1983 originally, was divorced by the end of the year and remarried in 84. Divorced again in 2000 and remarried in 02. I’ve worn a wedding band what seems like forever… regardless what work I was doing. Cognizant of the facts, pay attention. (well, except for the woman thing, seem to have slipped a few cogs where they’re concerned)
@fireflies
Please build this light with Clear anodize. Pleeeeease!!!
It looks sooo coool!!!
