OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
680-713lms at 4.5-5.5 amps 6-7amps didn’t produce any more out put out of any single emitters I built and 2100lms at 14.5-15amps out of a triple. I have 9 of these emitters and only 1tested at 730lms the max I could get? I run them on 2S 3v 4.5-5.0 and 5.5amp buck drivers and a ramping D4v2 FETDD and a FETDD Guppydrv3 with the FET’s changed out and 24awg leads, no driver spring bypass drivers. All purchased from Led4Power on 16-20mm boards and 3 singles for the triple. My favorite is the custom M3 single 18350 Flat White with Fast-2-Gun rail attachment.
The hot spot is actually much smaller the corona is about half of the diameter, as the camera dose not quite capture it correctly, it’s is clean and tight in real life, and throws like hell for a 35x30mm reflector, You can see the beam as it lights the Stop sign a full city block down with out a problem even with all the street and house lights on in my hood!
I’ll run it on my Colt M4orgery for kicks… :wink:
Pulled a 22mm linear driver (14x7135 I think?) from my Enogear EC21/Nightwatch NS02 and put it in my Jaxman Z1 with a white flat. I magic smoked it on the first try too from over tightening the ring above LED.
~4.85A tail reading for 384kcd measured at 5 meters.
I wonder what results will be if these high cd flashlights measured at 15-20m. Just my mind working. if you read a super range thrower at 5m a very nice number but at 15-20m read much lower numbers you read wrong. Because the beam focused to 5m. And at bigger distances it will widening out and loose intensity. I always measure throwers at 10-15-20-25m and try to focus the light to get the highest intensity at 20-25m readings.
I’ll try to do that when I have the time. I managed to get 1600m. I compared the beam to an Olight M3X and it blew that out the water. Also compared it to a Nitecore TM38 and beam was still tighter though.
Put one in a VG-10-ish host using a 3A buck driver. The reflector is about 23mm diameter.
I’d say the hotspot diameter is about 10% larger than that of my XPL-HI Convoy L2 :smiley:
Next, I want to bump it up to ~5A or so.
I have two more of these emitters. I think one is going in a C8. The other will go into either my L2, or into an Eagle Eye X6.
You should try it in the M3X as well, it’s stunning !
I would if have it. The M3X and TM38 was a friend’s one.
I plan to put one in an M2X in a few days.
I’ll tell you how it turned out
I put one in a Supfire F5, that was housing a dedomed XP-G S4 2B before. It did exactly 100kcd with the XP-G2. It is not a well-known light, a well-built 18650 zoomie with effectively 26mm plastic lens, here’s a pic.
Everything was done thermally as good as possible in this host. I first removed both spring bypasses and then added them again one by one because I hoped to get into the 130’s kcd. I ended with 120 kcd at start, 110 kcd at 30 seconds (with 500lm flood, 165lm spot). Still an improvement over the dedomed S4 2B, and certainly a better tint and beam shape, and contrary to the S4 2B the throw will hardly go down when the battery drains.
Btw, the Supfire F5 was always overpriced at 30 dollars but now I found it for 16.63 dollar shipped.
https://www.aliexpress.com/item/Mini-Led-Flashlight-CREE-L2-1100-Lumens-ZOOMABLE-LED-Flashlight-Torch-black-Fit-For-18650-Battery/32675972608.html?spm=2114.search0104.3.1.6c345cbaWXjh4I&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10068_5729915_319_317_5733915_10696_10924_453_10084_454_10083_5733715_10618_10920_10921_10304_10922_10307_10820_10301_10821_5730815_537_536_5733815_10843_10059_10884_5734015_10887_100031_321_322_10103,searchweb201603_51,ppcSwitch_0&algo_expid=d976e9bd-252d-4b3e-a73f-607659c0dc8d-0&algo_pvid=d976e9bd-252d-4b3e-a73f-607659c0dc8d
Dang! I am buying new EDC but I need something that won’t turn on accidentally in my pocket. But now you came with 120KCD for this tiny zoomie and that is OMG :+1: :beer:
Could you help me out in this thread Djozz? I mean Ultratac S20 thread Ultratac S20 - #45 by luminarium_iaculator I don’t know if you bought that light?
Edit:
Tail cap readings on your freshly modded supfire? Does it has anodized threads at the tailcap?
Just saw your review of Supfire 5 Supfire F5 review
I think on one pic is seen that it does not has anodized tailcap tube and switch threads. When flashlight has anodized threads we can turn it on/off with twist to turn move or just unscrew tailcap slightly to prevent accidentally turning on.
I never bought the S20 so I can not give an impression.
This F5 has bare tail threads, so no lock-out there. But with tail clickies I do not usually have problems switching it on in my pocket.
Btw, the F5 has a 20mm driver, and back in 2015 I did a review on it: Supfire F5 review
i would like to buy a cometa and put this led in there. which driver would be best? and do i need to think about something else? just the host driver and led right?
If you’re gabbing the led from them, why not get the L4p driver? You can pick your current.
I made a Cometa (from the recent trash sale on BG) with a KW CSLNM1-TG led (on stock 20mm Manker board soldered to pill) and 12-chip biscotti driver, it is doing 4.14A and 299 kcd at 30 seconds (and pretty steady at that).
I hope that the wavien collar that I will try to add next works well on this led.
It is full moon now so I could not resist the moon beam shot:
Do warmer tints exist for this emitter? Maybe something in t he 5000k range?
300kcd sweet! Did it take effort to focus the emitter?
Can’t wait to see your pics on setting up the wavien collar. I also have one waiting to be used so this will be very helpful! :laughing:
I wonder, how well would smaller reflector lights throw with this emitter!
For example, S2+ with SMO reflector and this led, and lets say 5A driver, what throw would we get!
Btw, I measured the hotspot of my Cometa mod at 8800K. I checked a LX1010B luxmeter against my Mobilux class A luxmeter, for this hotspot my LX1010B (that for neutral leds under-reads) measures 340 kcd which is more than 13% high (LX1010B calibrations may vary :stuck_out_tongue: )
The led is on the stock board and is about as thick as the stock XP-L Hi, so the focus is fine.
