Freeme, is there any update on the quiescent current? I don’t want a dead battery after a month sitting idle. Thanks.
It consumes about 5mA of the battery with breathing light ON. You can further reduce the drain by disabling the breathing function for final retail version. (Note: unable to disable on prototype due to incomplete firmware).
Please put me on the list for this one
Interested!
Is there any notification as to when these will begin shipping?
When not in use for long periods, just turn the tail cap for zero parasitic drain.
ooof, put that into perspective with the standby drain of the Q8: 0,135mA with the switch LED being shiny!
Isn’t this a bit too much? It would drain a 4000mAh battery in a bit more than 33 days o.O
All torches I have and I have several of them, have drainage below 0.1mA. All torches with an electronic side switch. Such a large consumption as FT02 has is a big drawback for me. It reminds me of Haikelite products, which also have such problems. I had HT07S HI and had 6mA.
LED intensity is rather bright. I have already informed BG. Astrolux S43S has only about 90µA parasitic drain after switched OFF for 6s.
freeme:It consumes about 5mA of the battery with breathing light ON. You can further reduce the drain by disabling the breathing function for final retail version. (Note: unable to disable on prototype due to incomplete firmware).
JohnnyUtah:Freeme, is there any update on the quiescent current? I don’t want a dead battery after a month sitting idle. Thanks.
ooof, put that into perspective with the standby drain of the Q8: 0,135mA with the switch LED being shiny! Isn’t this a bit too much? It would drain a 4000mAh battery in a bit more than 33 days o.O
In
Ordered 1 NW.
Interested
Interested
Sent.
Ordered 2 NW, thanks. I had all but forgotten about this one.
Can you use 18650s …Does it have an 18650 adaptor for those of us who don’t have any 21700 cels yet ?
It comes with adapter.
Thanks JasonWW
Ordered one NW, thank you very much.
Interested!
