What I mean is filing the threading of the retaining ring.
Underside, yes, but from the outside, to remove some threading so you can turn the ring a bit more.
Your picture, contactcr, shows filing down the inside of the retaining ring. You do that when the ring collides with parts on the spring side of the driver. This wouldn’t be the case here with the C8F.
Wouldn’t it be easier to just put a few solder blobs on the outside of the driver? I built mine with a 1.2mm thick 20mm FET+1 and had no issue but I guess YMMV. The ring is ridiculously thick so i’ll leave up the pic even though it isn’t what you meant.
Unfortunately I don’t have the 21700-C8F yet, so I can’t check myself.
I did this kind of filing several times with brass-pills (before the pill-less design took over) and it worked well to get the pill in deeper.
Of course you can do a comfy-style solder addon to the driver. Preferably the component side, as solder does not hold pressure well, especially not with a shearing force like from a retaining ring.
Btw, comfychair used a drill press to ‘mill’ these solder blobs flat. That was a classic.
Then there is the SP33.
I talked Sofirn again. They told me that talk with the engineer and will think about the songle led 21700 version. I said that make it like C8F so same double switch just change the front end to single led.
Like ZozzV6 said, the old SP33 was a single emitter 26650 light. I’m not sure why they changed it to xhp50.2 with boost driver. Maybe low sales? It might have been better to have 2 seperate models.
That good I like the 2 switch with forward click tail of 21700 C8F , hope for bigger head (55-60 mm.) with XHP35 for better throw and please make the light switch to stay on as locator .
I recently received 2 C8F 21700 hosts, along with a driver kindly sent by Sofirn, and today I found the time to assemble 1.
I used 2 pieces of 16AWG wire (about 4-5cm each), 3x XP-L2 V4 4500k 80CRI 3-step, and the Sofirn driver.
And I was really amazed by the result, I measured 17.8A max at the tailcap, with a 30T @ 4.2V
THANKS Sofirn.
I modded up a C8F 21700 host with 3 351D 4000K 90 CRI's and also measured 17.8A at the tail! Mine does 4150 at start, 3750 at 30 secs, but that's not ANSI lumens, more like manufacturer lumens. Measured 33 kcd throw. I used 20 AWG LED wires (long to re-program), and swapped the tail bypass to 20 AWG.
I got one more 21700 host on the way (hope so), and got in 3 C8F 18650 hosts, 2 modded up.
One C8F with XP-L2 V6 5000K actually read 19.1 amps on a VTC5D cell, 5640-5050 lumens, 42.5 kcd.
I hope they get in more - doesn't sound or look good. They don't seem to sell the 18650 versions any longer as well.
