What Legoes with What?
The JAXMAN 18350 battery tube is a perfect fit for the Sofirn SP31 and SP32A
The head of Sofirn SF14 fits on the body of the Sofirn SF10 , and the head of SF10 legoes with the SF14 body! FrankenSofirnStein :stuck_out_tongue:
Xref: Mateminco X6S, Factory Triple - #22 by DB_Custom
Hst tip tp DBCustom for that.
And scroll down in that review thread for more lego-info.
Streamer wrote here: [Sofirn Lightning Deal] Sofirn SP32AV2.0 only 20.99 on AMZ us - #67 by Streamer
Good Information. Thanks.
Convoy T2 head in Jaxman E3 body (I cannot test the E3 head on the T2 body has I removed the driver from it :zipper_mouth_face: Will try it when I het the driver :wink: )
pictures at the source post: [Available again! - BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED - #1754 by slowtechstef
hat tip to slowtechstef
I have found that the Convoy S2+ short tube (ordered from Convoy store) does not work with the Sofirn SP32A V2.0. This was a disappointing finding since MascaratumB reported that it worked in post 113 of this thread. However I now realize that was probably the V1 version. I also tried the tail cap from the Convoy S2, as this was reported to work by Streamer in post 122 above, and it does not fit. Again he says SP32 so I am not sure which version but I think V1. So as far as I can tell something is different about the SP32A V2.0 threads. If anyone has the V2.0 version and can find a short tube that works with it I would like to know about it.
Scientist, I am using the tube with the SP32 V2.0! The tube must be reversed, with the non anodized threads towards the tail of the Sofirn light!
Unless there was a new modification of the SP32 host (probable…) the tube will fit and work! I have one configured like that since I showed it in the picture!
Have you tried to use it reversed?
Yes I have tried both ways. The threads start but the tube does not seat deep enough. Perhaps I just have to try another tube.
ughly! just because you can, doesn’t mean you should!
geneticists take note!
Remember, disappointment is to be expected when trying to “lego” parts — all you can do is report your own observations, but we know from experience that Chinese lights don’t have reliably consistent threading.
See What Legoes with What? - #9 by hank
Sofirn C01 legoes with the Maratac copper AAA :partying_face:
:smiley: :smiley: :smiley:
Would be nice to get the smaller ones to light up :stuck_out_tongue:
Button cells? That would be cool to see.
Hum, would it be possible? :open_mouth:
djoozzzzz, can you try it? :smiley: Just for fun :partying_face:
LOL, no chance, the driver boards are already touching each other.
:weary: Noooo fun then :person_facepalming:
:stuck_out_tongue:
Hmm… Any chance a DQG Hobi or Fairy tube would lego with those? If so, there is a short extension tube available for those from Banggood. It should be long enough to fit two button cells back-to-back with a divider in the middle, to light up both lights. There are actually two versions of the tube, one with a divider already and one that is just an open tube. I have both.
The Convoy S2 vs Convoy S2+ 18650 & 18350 tubes!
As posted on another thread, the Convoy S2 gray (bought from Simon) can be used with the black & desert tan 18650 tubes and the gray, black & desert tan 18350 tubes!
Also, the S2 gray tube can be used in the “short” Convoy S2+ (blueish gray) [no photo of that one, sorry].
