I’m going to reshape my current tip to a point, clean it and give it a go on a mod before I invest much money. I need to pick up more wire, probably from MTN E…
Yup. Great little iron. Cheap, reliable, and replacement tips are at Fry’s too. I have 3 of them. :sunglasses:
Key things regardless of the iron: Flux, flux, flux. 63:37 solder (also at Fry’s by MG Chemicals along with their nice size flux bottle). Keep cleaning the tip with the solder tip cleaner “Brillo Pad” - Hakko brand @ Fry’s. Always, ALWAYS, keep your tip tinned. Especially before you put the iron away. It should be nice and silver bright. Tips will last you a long time if you do this. Oxidation is a tip’s worst enemy. Keeping it tinned is paramount.
Solder iron tips should be coated with a special metal. You don’t want to be scraping on it.
Contrary to what said earlier, using the brass shaving style tip cleaner is soft in comparison to the tip. It should not damagr the tip coating. Also, these types of tip cleaners do not suck a lot of heat out compared to a sponge cleaner. When I used a pencil iron with a sponge it would clean the tip well, but it also sucked out a lot of heat which took a while for the iron to replenish.
Going from a sponge cleaner to a brass shaving cleaner can definitely help.
High end irons have lots of power and can heat up in seconds and those seem to work fine with a sponge.
Here’s some helpful videos on soldering in general.
1 of 3 if you want to check out the rest.
What makes the above Hakko 888 iron so good? A lot of it is because of the high quality tips. A helpful hint is that you can use cheaper irons, but still the genuine Hakko tips (about $7 each) and it will make a cheap iron perform really well. I have some videos of my own showing why the cheap tips don’t work well.
Part 2 which is actual soldering.
Part 3.
Why use flux? Here is a really nice video on why flux is important. It’s pretty to watch as well.
I’ve used flux pens, but they can be thin and runny. I’ve used the hypodermic needle style applicators, but it’s very hard to control the amount that comes out. I definitely prefer the tubs of flux that you can scoop out with a toothpick. You can apply just the right amount. This is what you see in the last video.
Amazon is a great source for flux, solder, tip cleaners, etc…
I picked up some 60/40 Rosin Flux Core from ACE Hardware today. Made by: Alpha Fry, product # 31605. .032” diameter. Melts at 374F. Its a spool of 4oz. $9.99
So after doing a couple of flashlight driver and led upgrades I had to break down a buy a better iron. My Walmart cheapo iron wasn’t cutting it, it would go from working okay to dead cold, then warm.
I bought a Weller WLC100 and a 5 pack of conical pointed tips from Amazon. It has to be better than what I have been using.
Lead free solder totally sucks.
It refuses to flow nicely, even when you add a lot of flux.
(but maybe you need dedicated flux for lead free solder?)
Melting point is higher too.
I really hate lead free solder.
A small spade bit (shaped like a flat head screw driver, more or less) can be very useful for soldering wires to the LED board.
It has a bigger surface area at the tip, so it will go faster.
You can push down the wire with it too.
But a pointed tip is more versatile.
Sometimes i put on a sharp pointed tip for SMD parts (on drivers for example).
Conical are not very useful due to their small mass and small contact points. If they don’t perform well enough, you might buy some chisel tips. They have larger mass at the tip and can make better contact.
The wire you have has flux inside it. It burns away quickly so you want to feed the solder/flux into the joint. Having extra flux makes everything flow better and gives nicer performance. The videos I posted explain it.
Anyway, something you might try when you get wifi access is to download all the videos from YouTube using www.keepvid.work
I use it all the time to download 720p resolution videos to watch when I’m away from wifi. You get a popup junk page once per video, but it’s no big deal to me.
I’ve been using Kester 44 since the late 60’s. At first, I was using 60/40. Then in the 70’s I switched over SN63 (63/37). SN63 gives a brighter finish than 60/40 from my experience. That being said, I wouldn’t be caught dead using lead-free solder. It sucks big time.
