CRX Rotary - 6th Annual BLF/ Old Lumens Contest Winner
Are we there yet??
Great job :+1: :+1:
Just about ;)
Installed Cree XP-L HD v6 3D emitter, smooth 20mm x 14mm reflector, 22mm x 2mm ARC glass and light assembled :THUMBS-UP:
:open_mouth: :open_mouth: :open_mouth: :open_mouth: :open_mouth:
Sweet :blush:
Great work CRX :sunglasses:
It is nice, thanks mate :beer:
I’ll do some pictures when it’s light & maybe make a better video/ GIF.
A truly amazing job, CRX. Fabulous result.
My simple build just crashed and burned this evening…
O well…
Thanks mate. Sorry to hear that, it’s happened to me many times too but always a learning experience, even if at the most awkward of times.
That is a fantastic result! :+1: :beer:
It is hard to believe that that supernice flashlight in the gif above is completely built with hand tools! Only when you see the complete build thread you realise that.
Thanks djozz, yeah if you look close you can even see the hand tools latest inprint on my left thumb (hacksaw) :laughing:
CRX your builds are always amazing but I think this one take it to a new level. I admire your creativity, skill, and especially your patience.
Thanks very much, sure was a lot of patience went into this one O:)
Diffuser/ protective case.
I made a simple diffuser from an old berocca tube.
Rubbed down with wire wool to remove the printscreen, cut some from the length of the tube, installed a ring of stickyback felt inside the tube for a snug fit and added some GITD powder & UV glue to the ends.
Can also be used as a protective case for the light.
This light is so marvelous both in appearance and technique!
:slight_smile: :beer:
CRX Rotary - Complete.Specifications:
Copper & Titanium construction
GITD O-ring & LED surround
20mm Copper DTP MCPCB
19mm x 8mm solid copper heatsink
20mm x 12mm SMO Reflector
22mm x 2mm dual coated ARC glass
Lighted Rotary six mode tail switch & Momentary button
Dual colour Tritium indicators
Lockout-able
Diffuser/ protective carry case
Magnetic cell contacts
18350 cell compatible
Removable USB charging unit
Length – 94mm
Width – 25mm
Weight – 180g (With 18350 cell)
Parts Made - 80 (Approx)
Time to build - 101 hours
Modes, Operation & Light output:
Pressing the momentary button or turning the rotary tail switch clockwise gives these approximate outputs:
Mo Switch - 1560 lm
Mode - 1 - 1500 lm
Mode - 2 - 450 lm
Mode - 3 - 180 lm
Mode - 4 - 45 lm
Mode - 5 - 3 lm
Mode - 6 - FF lm
Max cd - 9000
Max Throw - 190m
The rotary tail switch can be operated through 360° in either direction starting in the highest or lowest mode.
The use of a lubricated o-ring underneath gives just enough friction for smooth operation.
The tail push button gives momentary access to the highest mode.
The tritium markers give an indication as to switch position/ charging mode.
When the two green tritium vials are lined up on the outer shell , the light is in the off position.
When the green indicator on the rotary tail section is turned to line up with the red indicator in the body section , the light is in direct drive mode, or in charging mode if the head section is then disconnected and the USB charger port is exposed.
Other than that the tritium indicators let me know where the switch is positioned.
Operational GIF
2016, 2017,& 2018 competition winners.
Upgrade Edit: 31:08:2019
I modified the CRX Rotary with a 3K carbon fibre jacket, swapped the XP-L HD 3D emitter for an XP-L HI 3A 5000K, re-made a new momentary tail switch cover, dual o-rings and added a seventh moonlight mode.
Carbon fibre, titanium & copper construction
Cree XP-L HI v2 3A 5000K emitter
20mm x 12mm SMO reflector
Lighted seven mode rotary tail switch & momentary button
Dual colour tritium indicators
Lockout-able
Length – 94mm
Width – 27mm
Weight – 192g (with 18350 cell)
New Modes, Operation & Light output:
Momentary Switch - 1300lm
Mode 1 - 0Ω - 1269lm
Mode 2 - 1Ω - 380lm
Mode 3 - 3.3Ω - 162lm
Mode 4 - 15Ω - 44lm
Mode 5 - 180Ω - 15lm
Mode 6 - 820Ω - 4lm
Mode 7 - 1200Ω - ML
Max cd 15000 - 245m
CRX Rotary revised runtime graph in modes 1 & 2.
CRX carbon fibre, titanium & copper triumvirate flashlight set.
beautiful work!
Such a refined and precise bit of craftsmanship there CRX
I take my hat off to you
I’m starting to believe that you are not human CRX. Is there something your not telling us? Should we be afraid? :sunglasses:
Thanks chaps :beer:
Course not, I like you guys :innocent:
Soo stay on your good side. Okay got it :wink:
Now that you have the protective case you must be ready to send it to me :smiley:
I agree with Moose, your skills are not normal :exclamation:
Wow! Unbelievably beautiful! :beer: Need to have this one Mass Produced! :heart_eyes: :+1:
Cheers David
